"accessory" key position? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > "accessory" key position?
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueToxic Brakes - 3000 PSI Braided Stainless Steel Brake Line
Unread 09-09-2014, 01:41 PM   #1
medic-11
My "accessory" position on my ignition key switch does nothing, and never has as long as I've owned the Jeep. I would like it to turn on the stereo like normal cars do. I even replaced the ignition switch on top of the column, and it made no difference. Anyone else have problems with theirs? I know its a GM key/tumbler/switch, I was just wondering if its supposed to work or not.
medic-11 is offline   Reply With Quote Quick reply to this message
Unread 09-09-2014, 01:48 PM   #2
XJ93
Is your stereo hooked to factory wiring or has it been "patched" in?
XJ93 is offline   Reply With Quote Quick reply to this message
Unread 09-09-2014, 05:39 PM   #3
sprngrider
Most likely it is wired directly to the battery, does it turn off automatically when you turn off the Jeep? If no, then that is the problem, not the ignition.
1994 2.5L WRANGLER S.
sprngrider is offline   Reply With Quote Quick reply to this message
Unread 09-09-2014, 05:41 PM   #4
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
If it is hooked up to a correct power source, the ignition switch may need to be adjusted slightly.
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade: http://www.jeepforum.com/forum/f12/9...grade-1287758/
5.7YJ is offline   Reply With Quote Quick reply to this message
Unread 09-09-2014, 08:11 PM   #5
medic-11
yeah it turns on with the key.
Unread 09-09-2014, 08:35 PM   #6
Old4X
1990 CJ7
There is a "radio" connection on the fuse panel. Your radio needs switched power to come from this connection for the ACC position to power it.
Some folks just tie into the switched ignition power instead of the ACC circuit. This gives switched power to the radio, but no ACC power to the radio.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline   Reply With Quote Quick reply to this message
Unread 09-10-2014, 12:34 AM   #7
Luuca
TYPICAL /F12 HOOLIGAN
Luuca's Avatar
Aaaaaand we have a winner. Old4X is dead on as usual. simple wiring fix and you should be good to go OP.
91 YJ "Alice" 2.5L, AX5, 2.5" OME 36Rs, 1" Shackles, 32" Yoko ATs, 4.10 D30/35 Busted Knuckles
05 LJ Rubicon "Ghost" 4.5" RE, 1.25" BL, 33" Atturo MT, 4.10 D44 F/R Locked
Luuca is online now   Reply With Quote Quick reply to this message
