AC info please. - Page 2 - JeepForum.com
post #16 of 24 Old 05-23-2010, 08:54 PM
pasinbuy
Originally Posted by Louie4 View Post
I started refurbishing my A/C and I was almost done but I ran into some problems. First I got the wrong drier so I had to get another one sent. Next my condenser had a leak so I still need to get a new one. I got my drier from Jeepair and they were pretty good. I also started a little thread about it but stopped updating because I was mad about the condenser having a leak.
http://www.jeepforum.com/forum/f12/c-refurbish-1010356/
Anyway, get a kit. I'd say its your best bet if you can't find someone selling theirs plus you don't have to worry about bad hoses, worn compressors, clogged expansion valve, etc.
I fully agree. With a used AC system you may not know what you are getting and recharging a system after a repair is not cheap. Also with a used system you are going to replace a few parts right off of the bat, drier, filter, mayby hoses due to age, etc. . Again fixing a AC system is not cheap. Might as well start out fresh.
pasinbuy is offline
post #17 of 24 Old 05-23-2010, 08:55 PM Thread Starter
Meatwad
Originally Posted by samsonitesamson View Post
Keep your eye out, I bought mine used on craigslist for $100
Man I'm a craigslist hooka! I got my doors, wheels/tires and hardtop from there. Even my radio, which is soaked and in operable.
Meatwad is offline
post #18 of 24 Old 05-23-2010, 08:58 PM Thread Starter
Meatwad
I honestly wish I could just pull the trigger, but I have a laundry list of crap that's gotta get fixed. Some left over problems, from the previous owner, are starting to rear there heads. AND my apartment owns meh. They got so mad when I spray painted my doors and used the curb to stand them up on....opps
Meatwad is offline
post #19 of 24 Old 05-23-2010, 09:08 PM
azgurney
Make sure you get a later model system that uses r134 freon instead of the old freon (R12?).
91 Wrangler 4.0 5sp
8.8 4.10 explorer axle, 33x12.50x15 x-terrains,Rancho 2.5 lift and shocks, Goforit 1" motor mount lift, 1" body lift, sailcloth top with tinted windows
azgurney is offline
post #20 of 24 Old 05-23-2010, 09:17 PM Thread Starter
Meatwad
Oh yeah, most definitely. I know how bad a conversion can go wrong if the r12 is evacuated completely and properly. Let me ask this. Does anyone know if a 4.0 compressor will fit a 2.5?
Meatwad is offline
post #21 of 24 Old 05-24-2010, 05:45 AM
Burnerman
Burnerman's Avatar
The compressor I'm using now is an R12 compressor out of Cherokee. I bolts right up to the stock 4.0 mount. the compressors are the same between all the YJ's. I converted mine to R134a several yrs ago and have had no issues. I did replace the o rings on the hoses when I reinstalled it. Blows cold as heck.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #22 of 24 Old 06-01-2010, 09:07 PM
SpideYJeep
Did you do the refrigerant conversion yourself? What did it entail? (I smell write-up!! )
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline
post #23 of 24 Old 06-02-2010, 09:21 AM
pasinbuy
The conversion is nothing more than a few differant O rings. A while ago my AC guy mixed R12 with 341 without changing the O rings and that car ran for a long time without any problems.
pasinbuy is offline
post #24 of 24 Old 06-02-2010, 08:49 PM
Burnerman
Burnerman's Avatar
To be honest I bought the kit at Walmart for around $40. It came with the R134a quick connect adapters for the 1/4" flare charge ports, an oil charge and 2 cans of refrigerant with sealer. I ran that for at least 2 yrs with no issues. When I installed the 4.0 I didn't have the proper compressor and removed the A/C. I got a suitable compressor so I reinstalled it. I bought an A/C o-ring assortment from Advance Auto for around $2, a can of oil charge,and 3 cans of R134a. I put in the new o rings on the hoses, vacuumed the system down to 400 microns, let it sit and it held @1000 microns. Added in the oil charge then 1 can of 134a. I ran the system on high and added enough 134a to get the bubbles out of the sight glass and Ice cold air out of the vents.
96 ZJ.
need lift info & regearing info stuart2410 JK Wrangler Technical Forum 3 01-18-2009 09:28 AM
Too much info...help rxl TJ Wrangler Technical Forum 5 02-28-2008 01:05 PM
Sat ant info nyr1583 JK Wrangler Technical Forum 3 10-05-2007 07:37 PM
Info plz SouthernBoy YJ Wrangler Technical Forum 4 03-31-2006 06:34 AM
Factory Warranty info? Top info? BlueRidgeRunner TJ Wrangler Technical Forum 5 06-27-2004 03:52 PM
