Ac bypass idler pulley for 87 4.2L serpentine - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Ac bypass idler pulley for 87 4.2L serpentine
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineToxic Brakes - 3000 PSI Braided Stainless Steel Brake LineCess Recovery Gear Snatch Tow Strap OffRoad @ ROCKRIDGE4WD
Unread 07-02-2014, 08:43 PM   #1
Dwarf
1987 YJ Wrangler
Hey guys,
I see it's been asked several times a while back and I haven't found a good answer yet. I have the ac/alt mount with the ac's front bolts facing horizontal and the back mounts facing vertical (with a bracket to go horizontal to the compressor). Has anyone found a good ac compressor delete solution?
Thanks,
D
Dwarf is offline   Reply With Quote
Unread 07-02-2014, 08:48 PM   #2
YJ4LIFE
you might have better luck in the CJ section. I go there for older 4.2L questions.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline   Reply With Quote
