AC Blower upgrade? - JeepForum.com
post #1 of 13 Old 09-05-2011, 09:10 AM Thread Starter
ptwhaler
AC Blower upgrade?
I think my blower motor might be going out. It's not blowing as hard and is surging a little. Are all the replacement motors the same as far as power goes or is it possible to get a motor that has a higher output than the original stock motor?
"In wine there is truth
In beer there is strength
In water there is bacteria"
ptwhaler is offline
post #2 of 13 Old 09-05-2011, 09:25 AM
uhohthe50
You will want to do the upgrade to a blazer blower motor. There are write ups on it if you search for them. I did it to mine and it makes a big difference. Kind of a pain to do though because you have to pull out the dash and cut a bigger hole in the firewall for the motor to fit
My 1990 YJ Build Thread: http://www.jeepforum.com/forum/f22/might-well-start-build-thread-now-my-1990-yj-1291174/
uhohthe50 is offline
post #3 of 13 Old 09-05-2011, 10:49 AM
timatoe
timatoe's Avatar
OP, I'm not aware of any upgrade for the A/C blower.
The A/C and heater do not share a blower motor. The Blazer motor and the stock replacement YJ motor are now the same motor btw, Siemens PM102.
timatoe is offline
post #4 of 13 Old 09-05-2011, 12:21 PM
TheNewbie
I think you have the A/C confused with the heater.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #5 of 13 Old 09-06-2011, 07:17 AM
vadslram
A/C????
What is this A/C you speak of?
When I need more cool air blowing I step hard on the skinny pedal, The only way to upgrade is os maybe bore and stroke the engine
vadslram is offline
post #6 of 13 Old 09-06-2011, 08:18 AM Thread Starter
ptwhaler
Originally Posted by vadslram View Post
A/C????
AC is kind of a required item when you live in the Middle East and it is 120 outside during the day
ptwhaler is offline
post #7 of 13 Old 09-06-2011, 08:45 AM
pasinbuy
A/C????
Pretty funny, if I lived where you do I probably would not invest in AC either.
Since I live in the Sub Tropics with 80 to 90 percent humidity and 95 temps. AC is a must, my dogs like it too. With AC they get to go with me more often.
pasinbuy is offline
post #8 of 13 Old 09-06-2011, 10:36 AM
Apollo12227
This, good ol' florida, and what is this 80 - 90% humidy your talking about lol? During the middle 2 months of summer we run at 100% humidity every day. This adds 8-12 degrees to the heat index which leaves a 97 degree day actually feeling like 106+ lol.
Anyway, I havn't heard of any reasonable upgrades for the YJ ac blower... I hunted around for options online quite a bit too. You can buy custom ac setups from Jeggs and Summit I believe, they are generic under-dash units just like the one we have but maybe they are better?
Just make sure your current system isn't leaking and that you have plenty of "ac fluid" in there lol.
Apollo12227 is offline
post #9 of 13 Old 09-06-2011, 11:29 AM
vadslram
FL aint so bad, when I lived in St Augustine I drove a 1969 MG Midget. It had basically anti A/C. If you leaned you leg against the tranny tunnel it sizzled like bacon.
But I was young and stupid then..I'm not young any more.
Since you're in the sandbox though I guess a little freon modification is in order.
vadslram is offline
post #10 of 13 Old 09-06-2011, 06:40 PM
czjeeper
I would like to upgrade my fan as well.
It doesn't seem to blow as hard as it should.
I wonder if an electrical rebuild shop could modify it?
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #11 of 13 Old 09-08-2011, 06:12 AM
dodger889
It's not the motor that needs upgrading it would be the whole unit would need to be replaced. A yj A/C is just enough to cool in the 100* or less that is to make bearable to drive. Now here is something you might want to do is pull the A/C blower out and give it a good cleaning and blow out the condenser or in another word a good maintenance cleanup of the whole system. Dry dusty air and moisture on the coils and blow squirrel cage. Gan make a good working system seem like crap when all clogged up.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #12 of 13 Old 09-08-2011, 07:42 AM
GromMudder757
I have 255 A/C! (2 doors off going down the road at 55)
Zak
My first jeep - 1992 YJ, 2.5, 5 spd, Rough Country 4.5" suspension lift, Brush Bar, 33x12.50 Dakota ATs, Uniden 510 cb
My mom, and brother have really helped me a lot with this project, if it wasnt for them my jeep would be in peices!
GromMudder757 is offline
post #13 of 13 Old 09-08-2011, 09:31 AM Thread Starter
ptwhaler
I guess if the fan keeps working a couple more months until it cools down I will just let it wait until after the first of the year. It's too hot, and humid, right now to work on it so I'll let it ride. Summers here are blistering hot but the winter is nice. 75 to 80 during the day and down to about 60 or so at night so I will be using the 255 A/C then . Really wanted to get a soft top on it this winter but just don't have the fundage for that right now.
ptwhaler is offline
heater blower upgrade FITZER123 YJ Wrangler Technical Forum 3 09-29-2009 03:25 PM
Blower Motor upgrade mikthebik YJ Wrangler Technical Forum 4 03-27-2006 01:26 PM
Blower motor upgrade... Bheleu33 YJ Wrangler Technical Forum 10 09-30-2005 02:20 PM
Blower Upgrade with A/C - Anyone done it? Jeep44 YJ Wrangler Technical Forum 2 09-30-2005 07:52 AM
88 Wrangler Blower upgrade Bheleu33 YJ Wrangler Technical Forum 9 09-26-2005 11:21 AM
