? about YJ axle vaccum part.....WHAT IS THE NAME OF THIS PART? - JeepForum.com
post #1 of 10 Old 04-28-2005, 01:27 PM Thread Starter
x19delta
x19delta's Avatar
? about YJ front axle vaccum part.....WHAT IS THE NAME OF THIS PART?
WHAT IS THE NAME OF THIS PART.....it is on the passenger side of the front axle, has three different hoses conecting to it, looks to be vaccum hoses and I believe it activates my 4wd on the front axle. One of the tips are broke off, my 4wd isnt engaging in the front axle so I think this is the cause of my problem. When it 4wd LOW it has the gear ratio that it should have but there is no spinning in the front axle. Anyways, I need to know the name of this part so that I can order a new one. Please help ASAP so I can get back in the trails! THanks!
Don't Drink and Park. Accidents make People!
"Lift it, Fat Chicks Can't Jump!"
"The only people to see the end of war is our dead."
1997 Jeep Wrangler. Black, 4cyl., 5 speed, black steelies w/31x10.50x15. 2" coil spring lift.
x19delta is offline
post #2 of 10 Old 04-28-2005, 01:40 PM
LandRover
LandRover's Avatar
4wd.com has a part called the "front axle disconnect switch assembly." that is the closest thing I could find to what I thought it would be called. I would think the word 'vaccum' would be in the name...I don't know if this is it or not because there's no pic:
http://www.4wd.com/shop/productdetai...oductsku=44060
RHD '98 XJ
RE 3.5", Bushwaker Flat Flares,
OR-Fab bumpers, PowerTrax locker,
Sliders, Goodyear Duratrac 33's
LandRover is offline
post #3 of 10 Old 04-28-2005, 01:41 PM
kg6mti
1987 YJ Wrangler
I don't remember the atual name of the part. I just replaced mine with a Posi-Lok system. If you are interested in mine you are welcome to it for the cost of the shipping. My original system worked just fine I just wanted the piece of mind in having the Posi-Lok engagement system.
Why are you wanting to replace yours?
Experience is what you get when you get what you didnít want.
kg6mti is offline
post #4 of 10 Old 04-28-2005, 01:46 PM
kg6mti
1987 YJ Wrangler
Sorry, I just re-read your post now I know why you are replacing the part.
Thanks!
kg6mti is offline
post #5 of 10 Old 04-28-2005, 01:48 PM Thread Starter
x19delta
x19delta's Avatar
Yes I would be interested, let me know how much to ship to 49766
One of the vacuum tips are broke off due to rust so I have to replace it to get it to work again.
x19delta is offline
post #6 of 10 Old 04-28-2005, 01:58 PM
kg6mti
1987 YJ Wrangler
Looks like it would be about $10.00 2 Day USPS Priority Mail or about $7.00 USPS Parcel Post (8 Days).
No I give no warrantee or life expectancy on this part. I can only say that when I took it off about 3 weeks ago it worked perfectly fine.
If you are serious let me know and I will PM you an email address to use for PayPal or an address that you can send a Money Order to.
Thanks!
kg6mti is offline
post #7 of 10 Old 04-28-2005, 02:34 PM
yoopers
I just did some work on my right front axle and the part according to the Haines manual is the shift motor. It's a vacuum motor that operates a shift fork to slide a splined collar inside the axle housing to lock in 4WD. It's an easy thing to remove for edification, four bolts and a slight tap on the motor housing to get it off. Careful to line up the shift fork on the collar upon reassembly. You may have to replace the cork gasket as well.
Bruce
yoopers is offline
post #8 of 10 Old 04-28-2005, 02:52 PM
rickr
when i put my posi lock in last month, i found my culprit--- shifting fork was broke! got new fork at dealer--- $36.10. wish i had waited and ordered a cast iron fork.
rickr is offline
post #9 of 10 Old 04-28-2005, 03:27 PM Thread Starter
x19delta
x19delta's Avatar
Thanks everyone, I found out what I needed to know, thanks!
x19delta is offline
post #10 of 10 Old 04-28-2005, 03:28 PM Thread Starter
x19delta
x19delta's Avatar
Thanks!
I will buy it from you, check your PM and PM me back with the email address! Thanks buddy!
x19delta is offline
Mucket Seal part number question (rubber part on door surrounds) commodog TJ Wrangler Technical Forum 6 07-12-2009 07:50 PM
help ...part behind alternator whinning..4.2l vaccum bcameron1974 YJ Wrangler Technical Forum 2 12-25-2008 07:43 PM
What is this part called and how do i replace it? (engine/air intake part) AlTheKillerr Wrangler General Discussion 3 09-12-2008 08:08 PM
Axle Seal Part 3 RUBtjICON TJ Wrangler Technical Forum 2 03-27-2008 12:49 PM
