about how much tube will i need for diy basic tube fenders??? - JeepForum.com
post #1 of 18 Old 01-01-2010, 03:07 PM Thread Starter
nathan2034
hey pretty self explanitory i want to build a simple set of tube fenders and i was wondering how much tube i would need to grab
thanks
nathan
nathan2034 is offline
post #2 of 18 Old 01-01-2010, 03:12 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
There are too many ways of making them, so I would advise measuring where you want the tube to be and go from there!
Just use a piece of string to mark it all out, then measure the string. Double that measurement will get you both sides.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 18 Old 01-01-2010, 03:15 PM Thread Starter
nathan2034
ya thats what i figured \
thanks for the quick reply
nathan
post #4 of 18 Old 01-01-2010, 03:44 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Mine have ~135" of tube for each tube fender.
Joe Dillard is offline
post #5 of 18 Old 01-04-2010, 05:36 PM
burnout189
should be able to get away with one 12 foot stick per fender IF it is JUST the fender with no flare. this should be enough but not much room for mistakes....
BARNHART'S AUTO REPAIR
burnout189 is offline
post #6 of 18 Old 01-04-2010, 07:21 PM
jbolty
jbolty's Avatar
mock it up with small size re-bar
jbolty is offline
post #7 of 18 Old 01-15-2010, 07:43 AM
KMA Krawler
12 foot per fender??? what type of jeep are you putting the tubes on?
Co-Founder/ Administrator
KMA Off-Road Jeep Club
KMA Krawler is offline
post #8 of 18 Old 01-15-2010, 07:50 AM
firefighter315
That doesn't sound like too much....Joe's measurements above are 11 1/4 ft. Those inches add up when you start to fill that straight tube with several bends.....
My YJ Build Thread
firefighter315 is offline
post #9 of 18 Old 01-15-2010, 08:58 AM
jeepster93
jeepster93's Avatar
Front or rear?
My rears took only 6 feet per side. Built and in use.
My fronts took 11 feet per side...Still in process on these.
here is a pic of the rear being layed out.
6 feet of HREW black pipe.
jeepster93 is online now
post #10 of 18 Old 01-15-2010, 09:27 AM
cheapjeep71
Those look great. Post pics of the fronts when done. I need to fab up some & am looking for ideas.
cheapjeep71 is offline
post #11 of 18 Old 01-15-2010, 01:02 PM
burnout189
yes i used one 12 foot stick per fender on my yj. thay are actually not totally finished yet but all the tube is together (no sheet metal yet). i did have a little left over but not much.... 10 foot stick might work if your careful.... not sure though.
post #12 of 18 Old 01-15-2010, 02:12 PM
KMA Krawler
Do you have some pictures? Doesn't matter if it's not done yet...just want to see how you are doing yours.
Thanks
post #13 of 18 Old 01-15-2010, 02:34 PM
ZeroGravity
Once you measure be sure to add at least a foot or two. I don't know about tube fenders but I know that it sucks when you realize that last piece is only 1/2" too short to finish the job.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #14 of 18 Old 01-16-2010, 03:07 PM
burnout189
Thanks
ok i have pics but i dont know how to post them..... im a "free" member... can sombody help? do i have to go through another website or something?
ok i cant figure it out but go to http://burnout189.shutterfly.com and scroll down to fenders album.
post #15 of 18 Old 01-16-2010, 04:18 PM
KMA Krawler
Why the second tube on the outside? Why not just one tube to come out that far and back to the frame? If you want to send me a couple pictures I'll post them for you.
Thanks
TNT tube fenders -vs- overkill eng tube fenders CCJ TJ Wrangler Technical Forum 44 12-02-2011 03:24 PM
Tube Fenders txboy72 TJ Wrangler Technical Forum 8 09-16-2008 06:13 AM
tube fenders motorhead0320 YJ Wrangler Technical Forum 6 05-19-2008 09:11 AM
new tube fenders canesqb3 TJ Wrangler Technical Forum 5 12-25-2007 08:19 PM
New tube fenders from T&T Wheelin98TJ YJ Wrangler Technical Forum 0 12-08-2006 02:44 PM
