-   -   ? about gas tank/skid plate (http://www.jeepforum.com/forum/f12/about-gas-tank-skid-plate-232755/)
Jeepfan Jeff 01-27-2006 06:32 AM
90 YJ, 4.2
I'm mounting a tool box in the back and I cant get to the fastener location. Will the skid plate come off without the tank dropping or does it all come down at one time? I also have a leak somewhere topside that need to be repaired.
TIA, Jeff
94Wrangler4.0 01-27-2006 07:07 AM
I think you will have to drop the tank if you drop the skid plate. Go to www.jeep.com and check to see if there is a recall for you jeep about the fuel tank gasket. Something about leaking and fire I wasn't real concerned about it on mine. 200K miles and no gas smell so I think it's okay.
Jeepfan Jeff 01-27-2006 08:04 AM
The leak is my own fault when mouting the tool box I drilled trough it:brickwall . I was being very careful not to do that. when drilling I couldn't find the hole from underneath so I thought there was second piece for sheet metal, but no... it was the tank. Iwas able to get a screw and rubber washer in it but itis still leaking:( . So thats what I'll be doing tomarrow.
blake989 01-27-2006 08:33 AM
it all comes down together. Before you drop the skid, take out the plastic fender gaurd thingy that closes the corner below the license plate, this will provide access to the fuel filler neck.
ryanalexander4 01-03-2010 01:13 PM
Does anyone know the Chrysler part number for the gasket?! I need this part ASAP and the Jeep website only goes back to '95 for recalls!
Apollo12227 01-03-2010 02:43 PM
I had to make my own... They don't sell it anywhere. Advance/autozone has a big sheet of gasket material that they sell, this is all I used and I have zero leaks or fume issues.
yj98joe 01-03-2010 03:01 PM
looks like a fine place for some mighty putty!
TSEJEEPERS 01-03-2010 03:15 PM
Got my gasket at the dealership. I had to order it.
The time now is 01:19 PM.
