!990 yj clutch kit - JeepForum.com
post #1 of 3 Old 05-02-2013, 04:45 PM Thread Starter
Smelly2u
!990 yj clutch kit
Got my new clutch kit!
plate, clutch, dummy drive shaft, slave, and a small lead like pin and small washer lock what are the last two things for? I can't remember seeing these two when I uninstalled the unit a few weeks ago? (meaning the small lead and lock washer)
Thks!
Smelly2u is offline
post #2 of 3 Old 05-02-2013, 10:53 PM
jokerchief462
The small washer lock is actually a called a push nut. When you get the internal slave cylinder out you will see one holding the cylinder on an index pin to keep it lined up. The small pin holds the inlet line from the master cylinder into the slave cylinder. There should also bee two small O-rings in a plastic bag which ar put into the slave cylinder before you reinstall the hydraulic line. Then you use the lead pin as you describe it.
Hope that makes sense if not when you take it all apart be slow methodical and keep all parts you remove you will find a use for all the new ones. Hopefully you also had a new pilot shaft bearing which goes in the flywheel.
Read all the directions that came in the box and it will help. If you have problems because there is so much labor involved take a picture of what or where you have the question and post up here. This gang of experts can get you through the process.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 3 Old 05-02-2013, 11:40 PM Thread Starter
Smelly2u
Cheers man thks for the tip have bearing!! Looking forward to the install have taking the underside all down and replaced now its put back time!!! Had the jeep since August lol
Smelly2u is offline
