99 Tj Ax5? Ax15? To 92 Yj Ax5 Swap??? Help Please - JeepForum.com
post #1 of 1 Old 09-04-2009, 11:44 AM Thread Starter
whatmud78
Does anyone know what all is involved in swaping out a 1999 TJ ax5 or ax15 (not quite sure which on comes in the 99 TJ, how do you tell the difference?) to my 92 YJ ax5? I've heard that the bell housing/slave cylinder set up needs to be changed along with the pilot bering possibly. Is there somthing different with the input/throwout bering? Will the transfer case swap with the assembly? I know the different years may have different electrical connectors on the tranny/transfer case that will need to be swaped. Any help?
whatmud78 is offline
2.5L AX15 swap czjeeper YJ Wrangler Technical Forum 2 12-26-2008 06:38 PM
AX5 to AX15 swap gatorkiller YJ Wrangler Technical Forum 5 05-20-2008 12:34 AM
305 Swap into my YJ with ax15 jvidmar YJ Wrangler Technical Forum 2 08-28-2007 10:05 PM
ax5 swap for ax15 Hockey1 YJ Wrangler Technical Forum 2 07-10-2007 11:10 AM
ax15 swap 5.0YJ YJ Wrangler Technical Forum 5 11-30-2006 02:27 PM
