97 TJ Booster into 92 YJ - JeepForum.com
post #1 of 6 Old 04-14-2008, 12:40 PM Thread Starter
djfred
Hey whats up peeps.
Question here.
First of all I didnt think it would be this complicated, but i just recently got a TJ booster w/ MC (1997).
Took the Old YJ booster/mc out and i tried to fit it in place but the clutch cylinder was in the way and also the booster puller is short.
So what im thinking of doing is this.
Cut the puller a little and replace it with the orignal YJ puller.
Orginal one is 8 inchs in length (from booster wall to the end of the tip)
but TJ is short. so im going to cut it and weld the old one onto it to make it 8inch in total length.
I have not done this "yet"
any other idea that would help not cutting and welding.
I know you might say get a YJ 1995 Booster
its really hard to find an OEM one for a decent price and not pay Hundreds of $$$.
Thank you for your input guys.
I hope this kind of post has not been answered i have used the search on here and on google no reults came up.
--Now--
White 92 YJ -- RE 1.5" SOA -- BFG KM2 35x12.50x15 -- D30 (4.88 w/ ARB) -- Ford 8.8 (4.88 w/ ARB)
Sanden OBA
--Future Mod--
Flat Fenders
djfred is offline
post #2 of 6 Old 04-14-2008, 01:20 PM
ChevDog1
I thought of doing tha same thing, since I can't find a 1995 dual booster. The only reason I haven't is that a friend has a 97TJ on 35's - and he says his brakes suck also. Let me know how yours works.
ChevDog1 is offline
post #3 of 6 Old 04-14-2008, 01:25 PM
4.7stroker
I cut and welded, this worked quite well.
Also the brake lines are different.
You will need to remove the double flare and bubble flare the ends that go into the master cyl,
Unless you bought adaptors that is.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #4 of 6 Old 04-14-2008, 01:59 PM Thread Starter
djfred
I have 32" Tires on it now and it totally sucks no panic stop and hits the floor and i just got 35" will be putting those on soon.
Once i finish i shall take pics to show
Dwayne
When i bought the system it came with Booster/MC and valve all in one hooked up already. and the valve looks identical to the one already installed on my YJ as of right now...
So im sure all the line fittings would fit but only thing im worried about is the weld, (which i myself am not doing my friend is that has a shop)
How is ur brakes holding and which year did you use on yours?
--Now--
Sanden OBA
--Future Mod--
Flat Fenders
djfred is offline
post #5 of 6 Old 04-14-2008, 04:42 PM
4.7stroker
My brakes are very good.
I used a dual diaphram out of a 98 I believe.
They are pretty much all the same.
Dwayne
[url]
[url]
post #6 of 6 Old 04-14-2008, 04:48 PM Thread Starter
djfred
Sounds good I was just afraid of welding.
It doesn't break in the middle of braking.
Thank you
--Now--
Sanden OBA
--Future Mod--
Flat Fenders
djfred is offline
Bad break booster? YJake YJ Wrangler Technical Forum 3 09-08-2009 01:58 PM
'95 XJ M/C & Booster timatoe YJ Wrangler Technical Forum 7 11-27-2008 10:30 AM
Brake booster Bad? Devildog985 YJ Wrangler Technical Forum 14 08-29-2007 07:21 PM
Brake Booster ionakana YJ Wrangler Technical Forum 1 09-28-2006 08:08 AM
Brake Booster?? CarsonKetrowYJ YJ Wrangler Technical Forum 2 07-10-2006 09:07 AM
