97-98 TJ hard half doors on a 94 YJ? - JeepForum.com
post #1 of 5 Old 07-29-2010, 10:14 AM Thread Starter
drespecki
1983 CJ7
Just a quicky... I cannot find the answer. Will the hard half doors from a 97 or 98 TJ fit on my 94 YJ? Any details regarding this would be greatly appreciated
It only hurts while you're breathing..
drespecki is offline
post #2 of 5 Old 07-29-2010, 01:12 PM
muddy93
1987 FSJ Wagoneer
I believe that they will physically fit the opening, but the latch/striker setup is different between the YJ and TJ.
So, you’d either have to swap the striker on the YJ tub, over to the TJ style(but then you couldn’t run any other YJ doors that you have). Or, you could try to change out the latch in the TJ doors, but I have no idea if a YJ latch would fit, or even function in a TJ door.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #3 of 5 Old 07-29-2010, 01:28 PM
Destr0
I thought the windshield angle was different as well, but I am not sure...
Destr0 is offline
post #4 of 5 Old 07-29-2010, 01:45 PM
muddy93
1987 FSJ Wagoneer
You're partly correct. The windshield frame on the TJ's is wider at the bottom, where it meets the tub. So, even though the windshield glass(and outside of the frame) is at a different angle, the inside of the windshield frame(and door opening) IS the same as it is on a YJ.
muddy93 is offline
post #5 of 5 Old 07-29-2010, 01:48 PM
Destr0
OK, thanks for the clarification- I knew I had heard the TJ was at a different angle. Never had a chance to put TJ and YJ doors next to each other...
Destr0 is offline
Striker from full hard doors appears too big for hard half door? LEOinFL YJ Wrangler Technical Forum 1 05-24-2010 09:31 AM
hard topw fulls doors vs soft top w half doors airdevil85 YJ Wrangler Technical Forum 5 01-13-2010 10:37 AM
Half Hard Doors vs Full Hard....Key Cylinders Swappable? Hunta TJ Wrangler Technical Forum 17 05-13-2009 02:57 PM
Soft top? full hard doors vs. half doors jgarden TJ Wrangler Technical Forum 8 10-17-2004 02:00 PM
Buying TJ with hardtop & hard doors, but I want a soft top & half doors xxxxxxxxxxxxxxxxxxxgksspot TJ Wrangler Technical Forum 11 10-26-2003 09:16 AM
