95yj brake leak - JeepForum.com
post #1 of 27 Old 07-09-2013, 01:31 PM Thread Starter
jeepstillhaslif
95yj brake leak
Little by little it drains and becomes empty. My brake light is also on inside my dash. Could this be the reason y. Where do I start trying to fix this problem
jeepstillhaslif is offline
post #2 of 27 Old 07-09-2013, 01:37 PM
jeff_in_rc
First thing I would do is clean out the crud in the master and re-fill it. Then I would put the Jeep up on jack stands and pull each wheel and start looking for obvious signs of a leak or leaks, brake lines, front calipers, rear wheel cylinders and lines and go from there.
Something else to look for, is there brake fluid on the inside of the cab where the plunger go into the master? Then look at all of your hard brake lines.
Let us know what you find.
2004 Jeep Wrangler Rubicon
Member of the Gear Grinders 4WD Club
jeff_in_rc is offline
post #3 of 27 Old 07-09-2013, 08:07 PM Thread Starter
jeepstillhaslif
Sounds good looks Lk ill have another weekend project with the jeep. Seems Lk once you fix one problem another pops ups.
post #4 of 27 Old 07-09-2013, 08:10 PM
TSEJEEPERS
That resevor is for the rear brakes.
I would start out with the rear wheel cylinders.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is online now
post #5 of 27 Old 07-12-2013, 07:20 PM Thread Starter
jeepstillhaslif
Finally able to work on jeep tomorrow been working all week and school. So besides tires coming do I need take part drums or should I be able to tell from just looking
post #6 of 27 Old 07-12-2013, 07:27 PM
TSEJEEPERS
Have someone pump the brakes while you look for leaks.
If you do not see any pull the drums off and see if there is fluid around the wheel cylinders.
post #7 of 27 Old 07-12-2013, 07:44 PM
pasinbuy
Yes. You will, pull the rear wheels. Pull the drums.
pasinbuy is offline
post #8 of 27 Old 07-17-2013, 08:21 PM Thread Starter
jeepstillhaslif
So I pulled th rear wheels off yesterday and the drums did not want to come off. Will a couple of hits from a rubber hammer solve this. Or what's ur option on this. Don't even no when the last they came off I'm assuming over 4 yrs ago
post #9 of 27 Old 07-19-2013, 07:47 AM
jeff_in_rc
Yes, smack them a few times and they will come off.
post #10 of 27 Old 07-19-2013, 08:22 AM
SeanB95YJ
depends on when the last time they were done... could be (hopefully) just a ring of rust around the edge of the drum not allowing it to slide past the shoes... remove the rubber plug from the back and with an adjuster tool (or flat blade screwdriver) turn the star adjuster to move the shoes inward - then a couple whacks with a mallet should free it.
hopefully it won't be the situation I found myself in a couple years ago when I did my brakes... it wasn't the rim of rust that was keeping it on, but the drum had sort of "rust welded" (term my brother gave it) itself to the axle flange... I ended up going through 3 sawzall blades and 4 cutoff discs to cut enough of the drum away that I could get a pry bar between it and the flange to pry it off.
as far as leaks, I'll agree that you should start at the wheel cylinders and work your way forward while someone is pumping the brake pedal... but I respectfully disagree at the need to remove the drum just to check for a leak.... any leak in the wheel cylinder (the only hydraulic part inside the drum) will make itself visible on the backing plate, shoes or if it's enough, actually dripping from the drum.
my vote would be somewhere around the junction of the hard line and hose - up at the frame mount above the rear axle
Good luck
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #11 of 27 Old 07-19-2013, 09:31 AM
jokerchief462
Clean the area the axle and drum come together with a wire brush. PB blaster and then if all else fails heat.
But like said above you need to back the adjusters off so the brake shoes relax the drum will get a wear lip on the braking surface and you won't get it off
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #12 of 27 Old 07-19-2013, 10:58 AM
jbolty
jbolty's Avatar
DO NOT pump the brakes with the rear drums removed. You will blow out the pistons and cover everything in brake fluid.
If you are losing that much fluid it should be pretty obvious where it's coming out
jbolty is offline
post #13 of 27 Old 07-19-2013, 11:56 AM Thread Starter
jeepstillhaslif
Well this is good to no. It's not a big leak its slow. Takes about 1-2 before its completely out of break fluid again. Picture shown above. And my brake light is on and need it to shut off so I can pass inspection and there's all this build up of grease so its hard to tell if its leaking brake fluid at that spot. My jeep doesn't roll or anything when I have the e brake on. How does the computer no to turn my light on
post #14 of 27 Old 07-19-2013, 12:03 PM
SeanB95YJ
your e-brake is activated by cable, not hydraulic pressure
your brake warning light is activated by a pressure sensor... if you follow the hard lines from the master cylinder, you'll see they go down to a brass distribution block... in that block is a sensor with 2 wires (black & white IIRC) coming off of it. this senses inadequate hydraulic pressure and turns on your warning light.
swap/build thread:
post #15 of 27 Old 07-19-2013, 12:11 PM Thread Starter
jeepstillhaslif
If its the one where it looks lk 3 or 4 brake lines are coming out of it I no which part ur talking about. So if its sensing in not getting full pressure to the rear the light will come on. By any chance can it be that brass block that's the problem
