95 yj wont go past 63 mph on interstate - JeepForum.com
post #1 of 33 Old 01-13-2014, 09:25 AM Thread Starter
bsundacvr
I have a 95 yj with a 4" lift on 33" tires, jeep struggles to get up to speed, will barely do 65 mph, anyone else have this problem???
bsundacvr is offline
post #2 of 33 Old 01-13-2014, 09:40 AM
AmmitOsiris
AmmitOsiris's Avatar
How I dare reply.. But. What gears do you have?
DISCLAIMER: YOUR ACTIONS ARE CURRENTLY BEING MONITORED.
AmmitOsiris is offline
post #3 of 33 Old 01-13-2014, 09:41 AM
AmmitOsiris
Also engine and trans.
post #4 of 33 Old 01-13-2014, 09:46 AM
Old4X
1990 CJ7
Fill out your profile
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 33 Old 01-13-2014, 09:51 AM Thread Starter
bsundacvr
Stock gears, it's a 4.0
post #6 of 33 Old 01-13-2014, 10:01 AM
Que89YJ
Even with a 4" lift and 33s you should be able to do the speed limit on the freeway. Please fill out your profile as complete as you can. It is necessary to give you good advice.
Que89YJ is online now
post #7 of 33 Old 01-13-2014, 10:17 AM
AmmitOsiris
Especially if you have a 4.0. You definitely be able to keep speed, is your engine up to par? Does it have a miss here and there? Last tune up, .... I have no clue.....
post #8 of 33 Old 01-13-2014, 10:27 AM Thread Starter
bsundacvr
Just had tuneup, ran fine before the lift and tires, switch out to 411 gears maybe?? Runs good around town, just doesn't have the balls on the freeway!
post #9 of 33 Old 01-13-2014, 10:39 AM
Mark05059
don't shift into 5th gear as early
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #10 of 33 Old 01-13-2014, 11:06 AM
EABiker
Did you change the speedometer gear when you went to 33's??
EABiker is offline
post #11 of 33 Old 01-13-2014, 11:06 AM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Still. Can't. See. Profile.
I have a 4.0 w/auto, stock 3:56s and 33s...60-70 mph is about it.
Bare in mind, unless you have changed the speedo gear, that 63 mph on the dash is closer to 70...
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #12 of 33 Old 01-13-2014, 11:13 AM
brzehentmaier
brzehentmaier's Avatar
With a strong headwind, a slight incline and I swear I can run faster than my 2.5. Be thankful you can reach 65. But it's a jeep so I don't mind.
Bernie
1995 Rio Grande
31 x 10.5 x 15 Tires
1.5 Body Lift - Skyjacker Hydros
2.5 - Auto - Crager "D" Slots
A Work In Progress
2004 Liberty Columbia Pkg.
A new begining
brzehentmaier is offline
post #13 of 33 Old 01-13-2014, 11:26 AM Thread Starter
bsundacvr
I got it to hit 70 today, speedo says 64, GPS speedo says 70, I rarely go on the freeway, oh well, thanks for the responses
post #14 of 33 Old 01-13-2014, 12:03 PM
Adams77
Bernie
Adams77 is offline
post #15 of 33 Old 01-13-2014, 12:12 PM
EABiker
Your speedometer is reading low because the speedometer gear in the transmission is for the stock tire size and now, you have larger tires requiring a different gear.
EABiker is offline
