95 YJ violent shakes after 60+ - JeepForum.com
post #1 of 24 Old 02-16-2012, 08:32 PM Thread Starter
djmanns
I'm running out of ideas. I drove my jeep home after purchase in 4th gear at 70 mph and didn't have any shakes. Since that time I have fixed 5th gear (AX5) marking the driveshafts to make sure they went back in the correct place. I replaced a destroyed front passenger side u-joint. I got everything back together and now have a shake that starts at 60 and intensifies up to 70 (too scared to go faster) no vibrations at any other speeds or RPMs. It's not 100% of the time but close. Today I was troubleshooting got to 65 and no shakes immediately but they starts by the time I was half mile down the road. It doesn't matter if it's in 4th, 5th, or neutral underpower or coasting at 60 + once it's shaking it get's worse till I drop below 60. I rotated the tires and checked the tire pressure and find it hard to believe tires went that far out of balance sitting in the garage on jack stands. I jacked the jeep back up and tried to make sure the hubs are tight. I did break the torque bolt on the tranny and have that on order. I did notice the skid plate is pretty rusted out and put bigger washers on the 2 tranny bolts. Any suggestions? The vibration is not in the steering wheel or the seat it's everywhere. Everything shakes.
djmanns is offline
post #2 of 24 Old 02-16-2012, 09:35 PM
scubamc
Does it have a lift?
scubamc is offline
post #3 of 24 Old 02-16-2012, 10:00 PM
broken-wrangler
Front locker?
Try pulling the front driveline and go drive it around
Josh Ashley
broken-wrangler is offline
post #4 of 24 Old 02-16-2012, 10:42 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It's obviously a factory speed governor. You're lucky you don't have a delorean, those governors are dangerous.
Luck Favours The Prepared
Anticanman is offline
post #5 of 24 Old 02-17-2012, 04:43 AM Thread Starter
djmanns
No lift. No lockers. 100% stock with 31 inch tires.
djmanns is offline
post #6 of 24 Old 02-17-2012, 06:50 AM
cstone94
The steering stabalizer could be shot, is it still factory?
cstone94 is offline
post #7 of 24 Old 02-17-2012, 06:52 AM
Billy
Billy's Avatar
That's my guess...
Everyone IS out to get you, if you just believe in yourself and try hard enough!
Billy is offline
post #8 of 24 Old 02-17-2012, 07:09 AM
dillonjm
2013 WK
Its not the stabilizer. Many people incorrectly diagnose this as bad when they get shimmy/death wobble. It is never the root cause.
You have something loose in the steering or your suspension.
Could be bad TREs, ball joints, hubs, or suspension bushings. Could also be that your ubolts are loose or some are broken.
You're going to have to go through all of these things and check they are tight and functioning properly.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #9 of 24 Old 02-17-2012, 07:12 AM
cstone94
That too, I'd also take the tires off and take them to a tire shop and see if the tires are out of round. Are the tires oldish?
cstone94 is offline
post #10 of 24 Old 02-17-2012, 07:14 AM
hulkedjeep86
i had the same thing happen on my jk 07 wrangler , steering stablizer was shot so replace it and abousoultey no shakes or wobbling
hulkedjeep86 is offline
post #11 of 24 Old 02-17-2012, 07:14 AM
Billsbluejeep
This sounds exactly like what my 92 used to do... get to ~60mph and the whole thing would start shaking... It's probably the Extension Bushing on your slip yoke... It shakes because the bushing is worn and so it lets the drive shaft move ever so slightly in the SY, and since no drive shaft is 100% perfectly balanced, when you get up to higher speed (60-65 seems to be the magic #) your drive shaft shakes just like an out of balance tire.
One of the easy signs of the bushing being bad is leaking transfer case fluid out the SY...so it sprays all over the underside, look and see if yours is leaking, that might be a good clue (although I guess it's possible for the bushing to be bad and the seal be ok). And also, chock your wheels, take it out of gear, crawl under and shake the drive shaft... there shouldn't be any movement of the shaft that goes into the slip yoke, if there is, then that tells you the bushing is bad also.
The part I'm talking about is #32 on this diagram, http://www.quadratec.com/jeep-replac...del_231.php#32 ...but I found it easier to replace #31, the housing extension, since it comes with the bushing already pressed in. You will also need the seal (#30) and a tube or RTV sealant... that's it.
I fixed mine in about 2 hours last summer, and it's been smooth ever since... and it stopped my oil leak to
Billsbluejeep is offline
post #12 of 24 Old 02-17-2012, 07:18 AM
dillonjm
2013 WK
You didn't fix the problem. You applied a band aid.
A properly functioning suspension and steering setup does not need a steering stabilizer to prevent wobble. Its there to soak up a little of the feedback you get from variations in the road not loose or sloppy steering/suspension components.
dillonjm is offline
post #13 of 24 Old 02-17-2012, 07:27 AM
Billsbluejeep
I would argue against this... his problem is speed dependent, which means it's something that increases it's movement as the speed increases, but is independent of engine speed or what gear it's in... so it's something like a axle, tire, or drive shaft. Even if you had a bad steering stabilizer, that wouldn't be the "cause" of a shake, since the stabilizer doesn't move... you need something that moves to be out of balance to cause a shake.
Don't take this the wrong way... I just don't think that's his problem.
post #14 of 24 Old 02-17-2012, 10:15 AM
Apollo12227
Op, Remember:
1. Shaking felt predominantly through the steering wheel SUGGESTS front end cause of vibration.
2. Shaking/vibrating felt predominantly through the drivers seat against your rump signals vibration coming from rear axle.
Recommended Troubleshooting for FRONT END vibration:
1. Pull front driveshaft and test drive, if vibes are still present... continue below.
2. Pull the rear driveshaft (cover the end of transfercase output cone with a cut soda bottle of you don't have a SYE to prevent loss of tcase fluid). Drive with just front driveshaft.
NOTE: If removing either driveshaft fixes the problem, you have found the grimlin. If testing w/o driveshaft(s) produces no change, then proceed.
3. Check for bad hub/unit/wheel bearing: (jack up front tire and check for ANY play towards/away from vehicle in the tire)
4. Check for play in front axle shaft ujoints (unlikely if you still have a functioning vacuum central axle disconnect), .
5. If your axle shaft ujoints check out, the hubs check out, move on to ballpoint and tie rod inspection. Basically, see if any play is present in the baljoints when trying to wobble suspended tire by hand. If any play is detected in the ball joints they must be changed. You can also check for play while having someone visually monitor the balljoints while turning on flat dry pavement, this will put great strain on the joints and any play should be noticable when turning from 0 MPH.
NOTE: You need to isolate the problem area before we talk solutions. But if driveshaft angles are correct (or if you are not lifted) then the problem is in the front in (my guess).
Apollo12227 is offline
post #15 of 24 Old 02-17-2012, 10:16 AM
19OlllllllO41
19OlllllllO41's Avatar
X2, the problem lies somewhere else, its not the stabilizer.
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
vibration
violent shaking at 60 mph Aduffy32 YJ Wrangler Technical Forum 20 03-13-2010 11:55 PM
Violent Vibrations! scottieboy YJ Wrangler Technical Forum 11 01-19-2009 12:40 PM
Violent Shake! jeepmuddin2005 TJ Wrangler Technical Forum 11 07-11-2006 05:37 PM
violent shake at 50+ mjeselskis YJ Wrangler Technical Forum 16 10-12-2005 05:32 PM
Violent vibration rv2g YJ Wrangler Technical Forum 21 11-12-2004 03:45 PM
