95 yj tranny questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 95 yj tranny questions
Rough Country Lift Kits now available at Baseline 4x4 OutfHeavy Duty 2007-2013 Jeep JK Wrangler Perfmance Ball Joint1 Ton Heavy Duty Steering Upgrade Kit. New and Improved d
Unread 03-25-2015, 07:52 PM   #1
nayroe
I have a 95 rio grande edition which has a 2.5 liter engine and an ax 5 transmission I was wondering if an ax 15 tranny and bell housing from a 92 wrangler 4.0 liter 6 cylinder would fit my jeep
nayroe is offline   Reply With Quote Quick reply to this message
Unread 03-30-2015, 12:32 AM   #2
Opihi59
from here it gets rough
Opihi59's Avatar
No, not a straight swap.
Read thru this: http://www.jeepforum.com/forum/f12/2...mplete-659386/
And also read thru this: http://www.jeepforum.com/forum/f12/l...p-pics-965067/
You would not want to go from your external clutch slave version, to an internal slave version, so if you did the swap in the first link, you'd also want to convert that 92 AX15 so you can stay external slave.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://kamfamily.wordpress.com/2009/...waiian-limpet/
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline   Reply With Quote Quick reply to this message
Unread 03-30-2015, 01:12 AM   #3
Anticanman
The Thunder Chunky
Anticanman's Avatar
The ax15 fits the jeep just fine. However it helps immensely if you have the 4.0 and 23 spline transfer case still attached to it.
Luck Favours The Prepared
"Whiskey is for drinking, Water is for fighting over" - Mark Twain
Anticanman is offline   Reply With Quote Quick reply to this message
