95 YJ Temp Sensor - JeepForum.com
post #1 of 12 Old 12-26-2013, 07:06 PM Thread Starter
ErMcG23
95 YJ Temp Sensor
Here is an interesting one:
I recently purchased a 95 YJ Wrangler which the previous owner had done an engine swap on. I was told the original engine was a 2.5lt, and that was what he had put in there, and is in there now.
My problem is with the temperature gauge. The sending unit for the gauge is there in the wiring harness, however there is no where to thread it into (usually in the drivers side rear of the cylinder head). I've cleaned the area and am positive there is not an old one broken off in the head, and there is nowhere this sensor will thread into!!
I have been told that some models have temp gauges while others do NOT, and just use an idiot light for over heating instead. My guess is that the original engine in the jeep came equipped with a temperature gauge, and the swapped engine did not.
Is there anything I can physically do, or even purchase to get this gauge working?? Any and all feed back would be appreciated!!
Thanks
ErMcG23 is offline
post #2 of 12 Old 12-26-2013, 07:15 PM
Que89YJ
The block is from the later model tj or xj that used the one sensor instead of 2. This thread is for installing a electric fan switch but will work to make the gauge work:
http://www.jeepforum.com/forum/f12/f...96/index2.html
or modify the tstat housing so it can take a second sensor there.
Que89YJ is offline
post #3 of 12 Old 01-04-2014, 08:55 PM Thread Starter
ErMcG23
Finally got around to this... decide to go the route of modifying the thermostat housing as I needed to replace the thermostat itself anyways. Engine is finally running at the temp it should be and the gauge works like a charm.
Thank you for the suggestion!
I'd be curious to see if there is an aftermarket company who makes modified thermostat housings for something like this... I could have sworn I've heard something similar like this before?!
ErMcG23 is offline
post #4 of 12 Old 01-04-2014, 09:12 PM
Que89YJ
Great! Why not just drill and tap the stock one.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #5 of 12 Old 01-04-2014, 09:34 PM Thread Starter
ErMcG23
That's essentially what I did... ended up buying a new housing, (for only $15) and drilled and tapped that. Wanted to have an extra one just in case I cracked it while drilling or if it leaked you know??
ErMcG23 is offline
post #6 of 12 Old 01-04-2014, 09:35 PM
Dake
Dake's Avatar
My replacement motor did not have a place for the temp in the head. I just put it in the block. but I like this idea at the thermostat.
Waiting on my Rough Country lift to sag!
Dake is offline
post #7 of 12 Old 01-04-2014, 09:38 PM
Que89YJ
Where in the block?
Fault codes:
No Start:
Que89YJ is offline
post #8 of 12 Old 01-04-2014, 09:51 PM
Dake
Dake's Avatar
Right under the exhaust manifold.
Sent from AutoGuide.com Free App
Dake is offline
post #9 of 12 Old 01-04-2014, 09:53 PM
Dake
Dake's Avatar
Its cold out these are the best picks got for now
Dake is offline
post #10 of 12 Old 01-04-2014, 10:25 PM
Que89YJ
Great pic. So it's in the rear about 1/2 way down the block. Did you have to tap it?
Fault codes:
No Start:
Que89YJ is offline
post #11 of 12 Old 01-04-2014, 10:34 PM
Dake
Dake's Avatar
No it had a pug in it. A brass plug I think I did this in 2002.
Dake is offline
post #12 of 12 Old 01-04-2014, 10:38 PM
Dake
Dake's Avatar
If I remember right it was an allen head plug. It was me n a buddy and lots of beer doing the engine swap. so some of the details are fuzzy.
Dake is offline
