95 YJ Stereo Help - JeepForum.com
post #1 of 6 Old 05-25-2012, 01:45 PM Thread Starter
Razorback23
95 YJ Stereo Help
I was running some new speaker wire today for future rear speakers I will be putting in. When I was all done I hook the stereo back up to jeep and it wont turn on. So i got out the multimeter and this is what I found, the yellow wire (constant 12v) is not getting any power at all. My red wire (Ignition 12v) is fine it reads 12.7 so im all good there. Im not sure what fuses to check I have pictures down below but there is nothing in the radio slot. So does anyone know where that yellow wire runs to so i can check it or is there a fuse anywhere that might have blown. Also my dome light in my hard top hasn't been working lately, I dont know if that has anything do with it? Thanks
Here is the fuse box under the dash, should something be going into the radio slot?
Razorback23 is offline
post #2 of 6 Old 05-25-2012, 03:01 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Check the fuse labeled "Radio".
Luck Favours The Prepared
Anticanman is offline
post #3 of 6 Old 05-25-2012, 04:05 PM Thread Starter
Razorback23
There is no fuse there. Look at the pictures above
post #4 of 6 Old 05-25-2012, 04:21 PM
sdotcarter
Check the wires. Mine were miscolored until I used a multi and found my true 12v.
sdotcarter is offline
post #5 of 6 Old 05-25-2012, 05:06 PM Thread Starter
Razorback23
My red wire(Ignition Power) is getting 12v but my yellow wire (Constant Power) is getting nothing at all. Shouldn't it still power on but just loose its memory when it turns off?
post #6 of 6 Old 05-25-2012, 05:33 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
I had issues getting a solid ground on my stereo install last week. Ensure your grounds are good. Also: many stereos have a fuse on the back of them, check that one.
Edit: My "Radio"Fuse is empty as well.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luuca is online now
1995 , no power , problem , stereo , YJ
Need to set up stereo in 87 YJ Dannyboy6292 YJ Wrangler Technical Forum 11 01-05-2010 03:44 AM
Stereo Help Gigidy Gigidy YJ Wrangler Technical Forum 29 04-22-2006 11:55 AM
Stereo fix... 95YJRookie YJ Wrangler Technical Forum 3 04-14-2006 10:52 AM
Tuffy Stereo Console vs. non Stereo Console Falcor TJ Wrangler Technical Forum 8 02-14-2005 12:39 PM
Stereo for my 92' JNC995 YJ Wrangler Technical Forum 5 03-31-2004 07:46 AM
