95 YJ Starter Problems! HELP - Page 4 - JeepForum.com
post #46 of 71 Old 05-13-2012, 09:09 PM Thread Starter
Razorback23
I went and picked up the supplies to rebuild the positive connection. I will put it together tomorrow and let everyone know what happened! Any suggestions on cutting and stripping a 4 gauge wire?
Razorback23 is offline
post #47 of 71 Old 05-14-2012, 05:30 AM
jsawduste
2006 YJ Wrangler
If all else fails the caveman approach will work.
A sharp chisel and a big hammer to cut the cable. Razor blade/knife to trim back the insulation.
jsawduste is offline
post #48 of 71 Old 05-14-2012, 07:06 AM
dauster500
1987 YJ Wrangler
Im not sure but couldnt it be the ignition coils or fuel pump? I had a friend with a no start issue on an xj made the same sound and it was his coils
dauster500 is offline
post #49 of 71 Old 05-14-2012, 08:53 AM
youngjeepr
If it cranked but didn't start it could be the coil or fuel pump. But his isn't even cranking
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #50 of 71 Old 05-15-2012, 08:53 PM Thread Starter
Razorback23
Ok, I put on the new positive cable that I ended up having made at a local auto parts store. I hooked it all up and the same clicking was still happening. I decided to push it down my driveway and pop the clutch to start it because it had sat for about 2 weeks and it need to be ran. So I drove it around for about 1 hour. When I got home I parked it and decided to try and start it back up. It finally started up, this is the first time. It dragged while doing though. Then I started it and it turned over like normal. I then let it cool down for about and hour and then started it again and it turned over like normal, all good. I'm not sure if I need to replace the battery or just leave it alone and see what happens. Maybe it just need to be ran to get everything flowing, this is the first time the new starter I installed has actually done its job! What do you guys think? I hope it's fixed!
post #51 of 71 Old 05-15-2012, 09:10 PM
tonymartin
I hope it's fixed for you too, sounds like it's OK now. I was speaking to one guy who said he took his starter off and stripped it down to clean it and when he put it back together it was like new. I've cleaned the solenoid and mine now actually clicks, but I will be cleaning the starter to see if that helps.
93 Renegade|Home made add a leaf (by PO, changing out soon)|Rancho adjustable shocks|31x15 BFG AT's|15" GT alloys|AFE Headers|Red SpiderWebShade Trail Cage|Free Sense of Adventure
tonymartin is offline
post #52 of 71 Old 05-15-2012, 09:33 PM
NeilBedwin
If your positive cable had a bad connection it is possible your battery has not been charging properly. So driving it with the new cable has charged the battery up and now it all works.
Tony, I had to replace the carbon brushes in my starter as they were worn down to the stage where they didn't touch the stator. Bought them online for $7 as opposed to $100 for a new starter! Small package easy to ship in.
NeilBedwin is offline
post #53 of 71 Old 05-15-2012, 10:11 PM
tonymartin
I'll look into that Neil. I will try cleaning the internals first and see how that goes and if not, then I'll order in the brushes. Do you have the link for the store you bought them from?
Cheers
post #54 of 71 Old 05-15-2012, 10:14 PM
NeilBedwin
When you take the cap off the starter it is fairly obvious if you need new brushes....they don't touch the stator!
http://www.shopjeepparts.com/starter...5_943_949.html
post #55 of 71 Old 05-16-2012, 09:03 AM
jeff_in_rc
Sounds like you may have found the problem BUT did you repair/replace the ground cable(s)? Also if you can't drive it for a while put a trickle charger on it to keep the battery "topped up". I have found that once you have a fully charged battery a product called a "Battery Tender" will keep it changed and it has a quick connect system that you leave on the battery making it a "plug-and-play" system.
jeff_in_rc is offline
post #56 of 71 Old 05-16-2012, 11:26 AM
tonymartin
Sorry to keep highjacking your thread mate, but I took the starter off today (Took ten minutes) then removed the casing and cleaned the internals. Put everything back together and BOOM!!! Fired right up!!! I think I will need need brushes soon though as all but one were almost worn to the bone!
post #57 of 71 Old 05-16-2012, 12:52 PM
akh21849
Watched your video.... wow can't believe some of the replies given.... definitly a power problem most likely a connection.... start with those part store replacement terminals... either take them apart and clean them starting with the location where the cables are stripped then move to the connection itself(on both terminals) There is nothing wrong with the after market terminals they just need cleaning more often. If the starter is clicking like this then power is making it to the starter indicating that everything is working properly, but you're starter isn't getting the required voltage.... relays either work or they don't. In 25yrs I have never had a relay only half way work and only one starter(new/reman) have a defect. I did watch your video.... and good job on the sound, that made the diff. in giving a good diagnosis. If you have anymore Q's you can email akh21849@yahoo.com .... I only signed up to see if this kid fixed his problem
akh21849 is offline
post #58 of 71 Old 05-16-2012, 04:43 PM Thread Starter
Razorback23
Came home from school today and checked and made sure the jeep would start. I went to start it up and nothing happened, only this strange clicking noise from the fuse box under the hood. So I took the lid off of it and the relay for the starter was acting weird. I took it out and put it back in and the jeep started but it was dragging REALLY bad. It finally started and I let it run for about 10 minutes and turned it off. I tried starting it again and it went back to the same clicking as before! This is getting really frustrating, I wish it was something other than electrical. I guess the relay is bad, I took out the AC relay and put it in the starter slot and still the same problem. Whats going on!
post #59 of 71 Old 05-16-2012, 05:23 PM
jeff_in_rc
Well??
Sounds like you may have found the problem BUT did you repair/replace the ground cable(s)? This is just as important and the positive cable.
post #60 of 71 Old 05-16-2012, 06:46 PM
Que89YJ
This is what you need to try. The next time it doesn't want to start pull the starter relay. There are 5 sockets for the relay. With the jeep in neutral and the key on take a 12 gauge wire and jumper pin 30 to 87. It is the contacts the relay makes when you are starting it. Post back what happens.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
1995 , problem , starter , wrangler , YJ
Starter problems YJMCB YJ Wrangler Technical Forum 4 12-18-2011 07:14 PM
Starter Solenoid or Starter Motor Problems hjlueth0001 TJ Wrangler Technical Forum 4 10-20-2011 09:50 PM
Starter Problems...HELP!! Maine-yj YJ Wrangler Technical Forum 11 07-27-2011 03:45 PM
Starter Problems(would TJ starter work?) Drastiq YJ Wrangler Technical Forum 2 10-14-2009 09:22 AM
2.5 Starter Problems Tradewinds YJ Wrangler Technical Forum 1 07-16-2009 03:48 PM
