95 YJ Starter Problems! HELP - JeepForum.com
post #1 of 71 Old 05-03-2012, 09:08 PM Thread Starter
Razorback23
I have recently encountered a problem with the starter on my 1995 Wrangler. I have taken it to auto zone to get tested, it passed the test they put it through twice. I also have had the battery checked by Walmart and it was good. I know it isn't the alternator because my gauge reads 12 volts when i turn on the key. When I go to start the Jeep all I heard is A LOT of clicking and it will never turn over. Please help this has been going on for about two weeks! I made a youtube video to show the problem a little easier!
1995 Jeep Wrangler 4.0L 6cyl
Razorback23 is offline
post #2 of 71 Old 05-03-2012, 09:56 PM
jdanthony
Sounds like its not attached to anything and it's just spinning
jdanthony is offline
post #3 of 71 Old 05-03-2012, 11:33 PM
lclark2074
Try looking at your ground cables. The one going to the motor is probley lose.
night crew 226
lclark2074 is offline
post #4 of 71 Old 05-03-2012, 11:35 PM
youngjeepr
Have you tested the battery? Also make sure the connections on the battery/ cables are clean.
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #5 of 71 Old 05-04-2012, 06:53 AM
Siva283
It says he had wal mart test the battery
Ask me how I know...
Siva283 is offline
post #6 of 71 Old 05-04-2012, 06:54 AM
Siva283
Have you had the battery load tested? Also without the alternator spinning you cant know if it is good or bad. It doesnt come in to play however until the engine is running. Have you tried jumping the starter. Try hooking jumper cables to the battery and connect the other end to the starter and see if it starts that way.
Siva283 is offline
post #7 of 71 Old 05-04-2012, 07:49 AM
yzjwk
2005 WK
http://www.youtube.com/watch?v=oMWgyu9JulU
That's your solenoid ratcheting cause you don't have enough juice .
tighten up that neg cable , way too loose if your wiggling it on like that .
then put a jump start on the battery and try to start it . If it starts , the battery is your problem , if it doesnt , turn your key to the on position and stick a big screwdriver between the 2 posts on your solenoid .it should start for sure then , unless the 95's use a fender mount relay AND solenoid like the 4.2's .but i don't see one anywhere in the vid .
good luck
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #8 of 71 Old 05-04-2012, 02:44 PM Thread Starter
Razorback23
good luck
I'll try that. I have popped the clutch going down a hill and got it started. If the screwdriver method works does that mean I need a new starter?
post #9 of 71 Old 05-04-2012, 02:47 PM Thread Starter
Razorback23
I have popped the clutch while rolling down a hill and took it for a drive. The volts stay good the whole time. Also I'm not sure how to jump the starter can you explain a little better?
post #10 of 71 Old 05-04-2012, 02:51 PM Thread Starter
Razorback23
That's what I thought. It sounds like the bendix on the starter isn't meeting up with the flywheel to turn over the engine. How would I fix that problem?
post #11 of 71 Old 05-04-2012, 03:15 PM
jeff_in_rc
OK from what I heard in the video and like the others have said, the starter is not engaging the flywheel, could be a bad solenoid. I would remove all of your cables and clean and re-attach them and like was said, be sure to check the ground on the engine block.
BTW just because your meter in the dash reads 12VDC it might be wrong. Put a VOM on the battery to see exactly what you have for voltage. Then turn on the ignition and see if the voltage changes. And just because it has 12VDC doesn't mean that it has enough of a charge to start the engine.
Next I would jump start it from another vehicle, if it starts that way without any problems you could have a low charge in the battery, charge it up and see what happens. If it does not start I would think that the solenoid is bad.
Let us know.
jeff_in_rc is offline
post #12 of 71 Old 05-07-2012, 05:13 PM
jeff_in_rc
So Razorback23, did you figure it out?
What was the problem?
post #13 of 71 Old 05-08-2012, 03:21 PM Thread Starter
Razorback23
I asked my local auto parts store and they said that the starter can still pass the test but when put under a load it still won't work. So I guess the best thing to do is to buy a new one.
post #14 of 71 Old 05-08-2012, 03:52 PM
jeff_in_rc
Did you try jump starting it first? If it starts that way you can just about be sure the battery is the problem. Keep us informed.
post #15 of 71 Old 05-08-2012, 04:28 PM
superj
do the tests man, i have replaced mine three time now in two weeks and two solenoids and it appears they weren;t entirely the problem. twice, the starter was for sure bad and the parts place said you can't test a solenoid so i think i bought another for nothing but after some more in depth checking, mine seems to be an ignition switch and a neutral safety switch. do the checks the guys tell you, especially the loose wires and cleaning hte connections. wire brushing my connections got mine running the first time i had starter trouble
I don't feel like working on anything at this time so i sold my yj.
superj is offline
1995 , problem , starter , wrangler , YJ
Starter problems YJMCB YJ Wrangler Technical Forum 4 12-18-2011 07:14 PM
Starter Solenoid or Starter Motor Problems hjlueth0001 TJ Wrangler Technical Forum 4 10-20-2011 09:50 PM
Starter Problems...HELP!! Maine-yj YJ Wrangler Technical Forum 11 07-27-2011 03:45 PM
Starter Problems(would TJ starter work?) Drastiq YJ Wrangler Technical Forum 2 10-14-2009 09:22 AM
2.5 Starter Problems Tradewinds YJ Wrangler Technical Forum 1 07-16-2009 03:48 PM
