95' YJ rebuilt engine, runs like garbage - JeepForum.com
post #1 of 6 Old 05-29-2013, 12:32 PM Thread Starter
95YJw
I just replaced the tired 243 engine (with a broken piston skirt on #4) with a remanufactured engine over the weekend. Now I can't get it to run worth a darn. I can start it but the timing is "retarded" what looks to be about 15 degrees. If I move the distributor one gear over, it won't start at all. At first I thought it was missing and backfiring because the fuel had to bleed the air in the system but it doesn't seem to be smoothing out and I don't want to do any engine damage. I'm very tired at this point and I'm not sure I'm thinking 100%. Help would be appreciated. I've not found any loose wires or hoses that would not allow it to run like it has since I bought it new in 95.
95YJw is offline
post #2 of 6 Old 05-29-2013, 01:55 PM
XJ93
Did you check the crank sensor? If it isn't in the exact right spot it will run like crap, and also check the wires to make sure they aren't pinched. Timing is controlled by the ecm so moving the distributor won't help if it was installed properly.
XJ93 is offline
post #3 of 6 Old 05-29-2013, 03:34 PM Thread Starter
95YJw
thanks for the suggestion, I will check the sensor location, I will also recheck the configuration of the distributor in relation to the #1 cylinder.
95YJw is offline
post #4 of 6 Old 05-29-2013, 04:51 PM
4.7stroker
How is the cam timing?
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #5 of 6 Old 05-29-2013, 06:53 PM
Odie4az
Where did you get the remanufactured engine? I'm looking into that also....
Odie4az is offline
post #6 of 6 Old 05-30-2013, 08:26 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
this has not been mentioned yet but are the plug wires in the proper location ?
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
