95' YJ mods. - JeepForum.com
post #1 of 12 Old 04-04-2002, 02:45 PM Thread Starter
boyd
95' YJ mods.
Great forum and lots of good advice. I am new here and in need of some experienced advice. I was thinking about replacing the exhaust manifold on my 95 jeep wrangler 4 cyl. with an aftermarket borla header. Has anyone done this. After talking with 2 mechanics they STRONGLY advised me not to do so as it would be more trouble than it is worth. They said that I would be back every 6 months or so to replace the gasket and that the mounting botls wouldn't stay tightened thus causing more leaks, also the gains wouldn't be that significant. Any comments on this? Also does anyone know where I can find a computer chip for a 4 cyl.
Thanks in advance
'03 Rubi
boyd is offline
post #2 of 12 Old 04-04-2002, 03:01 PM
Nine5YJ
Hey-
not sure about the exhaust... but i do know that they dont make computer chips for the 4Cyl 2.5L
95 YJ, 31 x 12.5 ProComp ATs / AR767 wheels, stock 4.10s, 2 1/2" Rough Country Suspension Lift, and huge rusty basketball sized drain holes.
Nine5YJ is offline
post #3 of 12 Old 04-04-2002, 03:12 PM Thread Starter
boyd
Thanks for the input. I have another question. Alot of people on here have put a 4.0L throttle body on. Will any 4.0L work or just the OEM Throttle body. turbocity.com has a modified TB for both the 2.5L and the 4.0L for the same price. Should I stick with the Mod. 2.5L or go with the Mod. 4.0L or will I get better performance with the OEM 4.0L.
Just looking for more power to pull me up the hills.
Thanks
'03 Rubi
boyd is offline
post #4 of 12 Old 04-04-2002, 04:03 PM
JeepBeep
Now I don't know about this turbocity modified TB, but your better off getting one off of a junker for much less money. Yes a 4.0L TB will fit your 2.5 intake. While your at it grab a Poweraid TB spacer, maximize your intake, along w/ your borla exhaust you'll be porting some serious air through your lil engine. I've got the TB and Spacer on my jeep and let me tell you, for the tires I have it really helps with the initial pick up and go. Also get yourself a K&N Filter and remove the restrictors from inside your Air Box. Let me know how the exhaust helps out.
'01 XJ BONE STOCK (Not for Looong)
'95 YJ 2.5L 3" Sus.
ProComp MT 33s"
JeepBeep is offline
post #5 of 12 Old 04-04-2002, 04:10 PM
AllanAlxndr
Will the throttle body swap work for my '90 2.5L?
Thanks for the help
Allan
***What do I know, I just cause Problems***
*'90 Wrangler*
*4 Banger*
*6" of lift, (4" suspension, 2" body)*
*33" ATs on Outlaw II's*
*Pioneer DEH3500/CD deck*
*1800WATT Amp w/ Custom Box*
*2 - 8" Rockford Fosgate HEs*
*Cobra 18WXSTII w/ 4' Firestik Antenna*
Member of
AllanAlxndr is offline
post #6 of 12 Old 04-04-2002, 04:20 PM
Bigrubberjeep
Is your 90YJ Fuel Injected (EFI)in each cylinder or is it Trotle Body Injected? My 89 is Trotle body Injected aka (TBI)
To Jeep or not to Jeep, what's the question?
Bigrubberjeep is offline
post #7 of 12 Old 04-04-2002, 07:58 PM
osburn
osburn's Avatar
A buddy and I installed a Borla header on his 2.5L YJ. A real pain in the butt. As is all exhaust work. But once it was done (like over 3 years ago) it was done and has never needed any kind of attention. I have a Borla header on my 4.0 and have never had any issues with it either.
Matt Osburn
Score 1032
osburn is offline
post #8 of 12 Old 04-04-2002, 09:35 PM
AllanAlxndr
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by Bigrubberjeep:
<strong>Is your 90YJ Fuel Injected (EFI)in each cylinder or is it Trotle Body Injected? My 89 is Trotle body Injected aka (TBI)</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">I also believe that mine is TBI
Does this mean No, I can not do the swap...
Allan
*'90 Wrangler*
*4 Banger*
Member of
post #9 of 12 Old 04-06-2002, 10:49 AM
clarky711
I had a 97 TJ, and I replaced the exhaust manifold. It wasn't too hard, a little pain in the butt, but it lasted fine for the 6 months I had it after the install. Also, I have a 94 YJ, and I removed the first restrictor in the airbox, but I have heard from a couple people that there is two restrictors?? I only found one. Thanks.
Mike
01 Sport, 4.5" RE LA, 35" BFGs, 4.88 gears in Dana 44s, ARB up front, Eaton E-locker in back, Warn XD9000i, and a bunch of other goodies.....
Previously: 01 TJ on 32s, 94 YJ on 33s, 89 xj on 31s, 97 TJ on 31s, 79 CJ5 on 31s.
clarky711 is offline
post #10 of 12 Old 04-06-2002, 11:43 AM
JeepBeep
clark, If you remove the intake house from the top of the air filter box and look inside the box top there is one, the other is down in the front of the lower portion of the box, near the headlight and the power steering fluid. Lower one is easy to remove, just get at it from the inside, the restrictor on the top of the box was a little pain.
'95 YJ 2.5L 3" Sus.
ProComp MT 33s"
JeepBeep is offline
post #11 of 12 Old 04-06-2002, 02:58 PM Thread Starter
boyd
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by JeepBeep:
<strong>clark, If you remove the intake house from the top of the air filter box and look inside the box top there is one, the other is down in the front of the lower portion of the box, near the headlight and the power steering fluid. Lower one is easy to remove, just get at it from the inside, the restrictor on the top of the box was a little pain.</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">What purpose do these restrictors serve?
'03 Rubi
boyd is offline
post #12 of 12 Old 04-10-2002, 12:10 PM
gtflyer
i inquired with quadratec about a Borla header for my 95 wrangler & said it will help significantly with performance,but turned me on to the gale bannk header they will be carrying..they said,it is a good if not better than the Borla & will be less $..just an option for you
gtflyer is offline
Since we have a worst mods, how about absolute best mods ever put on!! christrx450 TJ Wrangler Technical Forum 105 05-23-2008 12:37 AM
What mods should I get first? 2pac TJ Wrangler Technical Forum 4 02-03-2007 02:52 PM
Best First Mods wessy YJ Wrangler Technical Forum 20 12-24-2006 09:27 PM
My first mods on the way!! Marty315 TJ Wrangler Technical Forum 17 03-01-2004 02:52 PM
See your YJ w/ mods? TEXASRAM YJ Wrangler Technical Forum 6 02-05-2004 12:01 PM
