95 yj grinding in all gears - JeepForum.com
post #1 of 3 Old 11-05-2012, 09:06 PM Thread Starter
Coloradoyj1
Hey guys,
i have a 95 yj with the ax-15 and a 4.0L that has 144k. Started feeling some odd moving parts feeling through the shifter going into third, soon after that she started grinding into all of the gears. Last time i started her she was even grinding in neutral, but when i engaged the clutch the grinding noise stopped. Clutch, throw out, and pilot bearing were all done 30k ago. So is this trans cashed or could i get lucky?
Thanks
95 yj 4.0
90 xj 4.0
03 discovery s
Coloradoyj1 is offline
post #2 of 3 Old 11-05-2012, 09:17 PM
rogerv
Have you drained the tranny to see if any metal is floating around in there ?
If it's not broke- modify it, so it won't break
rogerv is offline
post #3 of 3 Old 11-05-2012, 11:17 PM
jokerchief462
Two things clutch slave cylinder or tranny. You have an external slave so no issue to see if it is working and just needs to be bled or replaced. Tranny like above mentioned a drain and search for metal or brass from the synchros. You can filter the drained fluid through some cheesecloth cofee filters etc to see what residue is in the oil. That way you can make a somewhat good decision on what is wrong and how to repair.
jokerchief462 is offline
