95 YJ front speaker removal - JeepForum.com
post #1 of 8 Old 08-03-2003, 03:04 PM Thread Starter
Trigger1911
How the hell do you get the front dash mount speakers out of my 95 YJ?
Trigger1911 is offline
post #2 of 8 Old 08-03-2003, 05:19 PM
LoOpY
some take out the dash. I found standing on your head with your feet on the head rest worked quickly enough. 1 1/2 hours remove and replace. patience is a virtue.
LoOpY is offline
post #3 of 8 Old 08-03-2003, 05:48 PM
DanG
DanG's Avatar
if you use the search there are several treads on the board about the subject.
i found a pry bar and alot of swearing worked
89 RED YJ
sitting in driveway next to wrecked car
NEOffRoading
H2RT MEMBER
RED JEEP MEMBER #49
POS JEEP MEMBER #3
DanG is offline
post #4 of 8 Old 08-03-2003, 06:33 PM Thread Starter
Trigger1911
I know how to swear pretty good. I have a crowbar and I could use my neighbors cat as a wedge to hold the dash apart. I also have a torch and visegrips. Am I ready to rock on this thing?
post #5 of 8 Old 08-03-2003, 07:22 PM
DanG
DanG's Avatar
pick up some beer to dull the pain from the cuts on your hand, and you'll be allset.
dont plan on getting all the nuts back on
89 RED YJ
NEOffRoading
H2RT MEMBER
RED JEEP MEMBER #49
POS JEEP MEMBER #3
DanG is offline
post #6 of 8 Old 08-03-2003, 07:26 PM
Moxley
Moxley's Avatar
Speaker Removal
Passenger side
1. Reach up behind the right side of the instrument panel and remove the four nuts retaining the speaker in place.
2. Detach the speaker and pull it out for access to the electrical connector. Unplug the connector and remove the speaker.
Drivers side
1. In the engine compartment, remove the nuts from the two parking brake assembly studs which project through the firewall.
2. In the passenger compartment, remove the bolt holding the parking brake assembly to the instrument panel, then lower the assembly out of the way.
3. Loosen the three torx bolts holding the drivers side windshield. This will make it easier to access the nuts holding the speaker. You can wedge something inbetween also to gain access.
4. With the speaker now accessible, remove the retaining nuts.
5. Unplug the connector and remove the speaker.
Good luck,
Doug
Moxley is offline
post #7 of 8 Old 08-03-2003, 07:40 PM
RCHavok797
RCHavok797's Avatar
I just did this on my 91 YJ. I loosenned the dash screws and was able to make enough room to remove and replace the speakers.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #8 of 8 Old 08-03-2003, 07:42 PM
DanG
DanG's Avatar
rc thats the same i did i loosened the screws and had a friend pry the dash out while i changed them
89 RED YJ
NEOffRoading
H2RT MEMBER
RED JEEP MEMBER #49
POS JEEP MEMBER #3
DanG is offline
Front speaker removal? Ghostdog2007 JK Wrangler Technical Forum 5 09-17-2007 03:32 PM
Removal of drivers side front speaker Sirptrk YJ Wrangler Technical Forum 11 07-29-2007 10:11 AM
Speaker removal SAB30 JK Wrangler Technical Forum 7 03-28-2007 12:37 PM
Speaker Pod Removal? Balmer Bill TJ Wrangler Technical Forum 4 11-07-2005 01:06 PM
Speaker removal bamakrw YJ Wrangler Technical Forum 19 02-19-2004 02:21 PM
