'95 YJ Dies while idling and braking - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > '95 YJ Dies while idling and braking
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options! RCV Axles at CCOR
Unread 03-26-2015, 07:21 AM   #1
plsmocke
Hello all, I recently got my first Jeep about 3 weeks ago. I traded my motorcycle for it knowing that it would probably need some bit of TLC. It runs perfect except every now and then when I'm making a turn or braking it will die; it doesn't have a slow decline in RPM's, it just dies. The same thing happens while leaving the Jeep sit and idle by itself. It will be fine for a couple minutes but eventually will die. It has a good sounding idle the entire time but just stops immediately. The things I have done so far after reading through a plethora of forums here:
-Replaced IAC
-Replaced MAP sensor
-Replaced TPS sensor
-Cleaned the Throttle Body inside and out
-Replaced the Fuel Pressure Regulator
Does anyone have any thoughts on what I can try next besides taking it to a dealership? Any input would be appreciated.
Thanks,
Pat
plsmocke is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 07:36 AM   #2
plsmocke
Oh I forgot to mention some other things I replaced:
-Spark plugs
-Spark plug wires
-Distributor Cap
-Rotor
Unread 03-26-2015, 07:52 AM   #3
TSEJEEPERS
Check the vacume line that goes inbetween the brake booster and manifold.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 10:03 AM   #4
mike134
when it is sitting there idling and dies, I assume it is in neutral?
I'd look at an intermittent CPS failure next. It is usually the culprit when the engine suddenly dies.
mike134 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 10:19 AM   #5
ghetdjc320
Does your speedometer work alright? A speed sensor failure can cause your engine to stall and die when you slow down. The speed sensor is located in the tailhousing of your transfer case. Make sure the connector is good and that the hold-down clamp is secure. Just one of many possibilities.
-DJC
ghetdjc320 is online now   Reply With Quote Quick reply to this message
Unread 03-26-2015, 10:25 AM   #6
Que89YJ
I bet you have power steering. Post back if you do.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 11:29 AM   #7
plsmocke
Thank you for the quick responses guys! I'll check that vacuum line tonight hopefully. Mike, it'll die when it's in nuetral or I have the clutch engaged and in gear. Yes, the speedometer works just fine and yes I have power steering. Once again, thanks guys.
Unread 03-26-2015, 11:46 AM   #8
Que89YJ
Power steering. You are having an issue with the load switch on your power steering. This post will show you where to look:
http://www.jeepforum.com/forum/f12/h...-hose-1214933/
Unread 03-26-2015, 12:41 PM   #9
plsmocke
Why do you think the power steering is what is causing my issue? The post you reference doesn't explain what the symptoms are for a failing load switch.
Thanks
Unread 03-26-2015, 12:56 PM   #10
Que89YJ
It doesn't idle up under load. Turn your steering wheel. Does it idle up? Look at the switch.
Unread 03-26-2015, 01:06 PM   #11
mike134
Its the sudden engine cutting off at idle in neutral that would make me think it might not be power steering or a lack of power at idle. Although, he didn't say whether he was turning the wheel when it happened. I guess I assumed he was letting it sit there and doing nothing.
Definitely worth checking if it bogs when turning the wheel though.
Unread 03-26-2015, 01:14 PM   #12
plsmocke
You are right Mike, it happens even when I am standing outside of it. I've spent at least an hour walking around it while running, listening for any odd noises. But yes, it will happen even if the system is not under load, like turning the steering wheel. One thing I just read in my manual is that the e-brake light on the dash might effect how the computer handles the RPM's. As of now, I have the e-brake removed and the switch wire closed to ground (telling the computer the e-brake is activated). I was going to try that tonight as well. But I would assume the e-brake being activated would not factor into the equation when the jeep is just sitting there and not moving.
Unread 04-01-2015, 07:07 PM   #13
Steve707
Hate to bump this but thank you. This solved my stalling issue.
Steve707 is offline   Reply With Quote Quick reply to this message
Unread 04-01-2015, 07:16 PM   #14
Que89YJ
It is usually stalls when coming to a stop when the speedo is bad. Thank you for posting it helped. Please give his post a thumbs up.
Unread 04-01-2015, 07:23 PM   #15
Steve707
I did, thanks Que. I had the clip in the wrong quadrant.
die , iac , idle , tps , YJ
