95 YJ currently running front wheel drive only - JeepForum.com
post #1 of 7 Old 02-10-2012, 12:09 PM Thread Starter
yoyoyo109
2015 JK Wrangler
so i was driving home yesterday and when i was literally less than 200 feet from my house, i felt a few lurches and then next thing i know my transmission is engaged and my engine is revving like crazy. Guessing what had just happened, i quickly cursed the previous owner for the poor air locker installation he had done and then switched into 4wd so that i could finish driving home. i jacked it up to see if my differential was shot but both tires spun opposite directions but the driveshaft was just spinning without any forward power so I'd guess my pinion gear was shot (if anyone reads this and knows better than me, by all means tell me what broke haha)
it rained this morning so once it was dry enough, i was going to take the differential apart to see what i was working with. can anyone recommend what ratio/brand I should replace it with? I've got the stock I6 with the AX-15 on 33" tires. not sure what the factory ratio was but i dont know too much about gear ratios so if someone could suggest a replacement that'd be great
I'll post pictures once I've taken it apart
yoyoyo109 is offline
post #2 of 7 Old 02-10-2012, 12:26 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
What rear axle is it?
If its a D35, this may be a good time to sell whatever is still "good" in the D35 & get a different axle.
Joe Dillard is offline
post #3 of 7 Old 02-10-2012, 12:37 PM Thread Starter
yoyoyo109
2015 JK Wrangler
I'm really not to sure. it might be stock for all i know. how do I check?
post #4 of 7 Old 02-10-2012, 12:43 PM
Que89YJ
Que89YJ is offline
post #5 of 7 Old 02-10-2012, 01:00 PM Thread Starter
yoyoyo109
2015 JK Wrangler
looking at that picture, the bolt pattern matches the 35 so lets say that's it
post #6 of 7 Old 02-10-2012, 05:36 PM Thread Starter
yoyoyo109
2015 JK Wrangler
alright i took it apart and it doesn't look as bad as i was expecting i suppose.
heres a link to all of the pictures, i cant post them directly
https://skydrive.live.com/redir.aspx...309&parid=root
what would you guys suggest?
there were six bolts sitting in the bottom of the diff case that look like they were designed to hold the big gear to the axles so those are all broken off in it, you should be able to see an example in one of the pictures
post #7 of 7 Old 02-10-2012, 06:26 PM Thread Starter
yoyoyo109
2015 JK Wrangler
D35-411ZZ is stamped into the gear in one place
will i need to replace the entire gear set? and should i keep the gear ratio the same?
differential , pinion
Front Wheel Drive shipsjeep1 TJ Wrangler Technical Forum 3 12-29-2011 07:23 PM
Running 4 wheel drive without rear d shaft? 1993sahara YJ Wrangler Technical Forum 25 11-01-2011 06:11 PM
Front wheel drive YJ better MPG? jagarcia82 YJ Wrangler Technical Forum 12 06-15-2010 07:15 AM
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 10:58 PM
running no front drive shaft? NYSCARLETKNIGHT YJ Wrangler Technical Forum 3 07-03-2006 04:58 PM
