95 YJ Clutch issue?? - JeepForum.com
post #1 of 4 Old 08-27-2011, 01:02 PM Thread Starter
internetscout
2011 JK Wrangler
First post here. I've been lurking for quite some time. Anyhow, I bought a 95 YJ several months back and in true jeep spirit it likes to get a new part every few weeks.
For about a week now I have been having what I think is a clutch issue. The jeep runs great as long as it is not under any load. As soon as you shift (AX-5) and begin to accelerate it starts to shudder and get "jumpy". It's as if the clutch is sticking perhaps and not allowing the transmission to fully engage. Kind of like it's only allowing power to the wheels every other revolution or something. As soon as you press the clutch again the engine revs up just fine and acts normal. If I really ease the clutch in and out I can avoid it but for normal shifts the problem occurs. Is this a master/slave cylinder issue or internal clutch mechanism?
internetscout is offline
post #2 of 4 Old 08-27-2011, 01:19 PM
Fin_Reaper
One possible cause may be motor mounts and its an easy check. With the hood up and trans in neutral, gun the engine (with the throttle linkage) and see if the mounts can resist the torque.
88 YJ with stuff
Fin_Reaper is offline
post #3 of 4 Old 08-27-2011, 01:41 PM
preto789
Not sure if helps but I have a 95 wrangler 2.5l with 100k miles and my motor mounts were shot.. I replaced both motor mounts and my Tranny mount and found out my drivetrain had shifted back almost two inches.. smoothed some of my shifting problems out but seemed to cause an issue with my throwout or something clutch related..
Sent from my Desire HD using JeepForum
preto789 is offline
post #4 of 4 Old 08-27-2011, 02:57 PM
kahanabob
like posted above check that the motor mounts are not shot. if they check out then the "chatter" is due to the clutch needing attention. can be crud on the flywheel or most likely worn out clutch,probaly both. if you end up replacing the clutch need to resurface the flywheel also.
kahanabob is offline
transmission issue ? drive shaft issue ? clutch issue..where to begin ?..... rthompson48082 YJ Wrangler Technical Forum 7 09-28-2009 05:07 PM
Clutch Issue (and more) itsajeepthang86 YJ Wrangler Technical Forum 1 10-27-2008 08:21 PM
91 YJ clutch issue kodiak1 YJ Wrangler Technical Forum 4 07-20-2008 08:25 PM
Clutch issue / bleeding clutch. Dravintoad TJ Wrangler Technical Forum 7 11-12-2007 11:50 AM
Clutch Issue Lyfisin TJ Wrangler Technical Forum 0 12-08-2006 07:40 AM
