95 Yj Brake Light On Help - JeepForum.com
post #1 of 4 Old 09-08-2008, 05:18 PM Thread Starter
95jeepyj95
Ok I Have A 1995 Yj The Red Brake Light Is On Fluid Full When Applying E Brake Doesnt Change Of Color Is Thier Something Common With These Portioning Valve Sensor
95jeepyj95 is offline
post #2 of 4 Old 09-08-2008, 05:24 PM
USMC_XJ
2003 WJ
i have the same problem. i believe that light is a pressure sensing thing. if the pressure or something is to low, then the light will go on. if the brakes are fine and you hate having a red light in your face when you drive at night, the disconnect it. its on the proportioning valve, its a harness with 2 wires. if you disconnect it, your light will go off but it will still light when you use the emergency brakes. :-) hope this helps
USMC_XJ is offline
post #3 of 4 Old 09-08-2008, 05:44 PM Thread Starter
95jeepyj95
Perfect Answer Thank You All
post #4 of 4 Old 08-02-2013, 01:13 AM
ashland82391
Well, guess I'm bringing this thread back to life :-)
My Jeep is doing the same thing. Brakes are fine, fluid is full. so to fix this all that needs to be done is a simple brake bleed correct?
ashland82391 is offline
CHEAP TJ BRAKE LIGHT MOD for SPARE TIRE LIGHT wheresgeorgenow TJ Wrangler Technical Forum 5 01-01-2012 07:45 AM
Brake lights wont light up except 3rd brake light yellertj4rob TJ Wrangler Technical Forum 21 08-21-2007 05:22 AM
Does you brake light come on as soon as you barely touch your brake pedal? it should Big-n-Broke-YJ YJ Wrangler Technical Forum 0 02-24-2007 08:31 PM
brake light switch (check engine light)? JoeBeJeepin TJ Wrangler Technical Forum 1 02-14-2006 04:48 PM
brake light/Hazard light fuse blows as soon as you install it! jeffro123 YJ Wrangler Technical Forum 6 08-23-2005 10:57 AM
