95 YJ 5sp 2.5l cracked transmission case - JeepForum.com
post #1 of 3 Old 10-23-2011, 07:55 PM Thread Starter
pipe00764
I had a leak where the transmission meets up with transfer case. i noticed what appears to be a hairline crack on the back of the transmission pretty close to where the transmission mount area is. A slight amount of gear oil is seaping out. should i try jb weld or should i find a mechanic to weld it?...do these things crack often?? and is the welding option expensive?
pipe00764 is offline
post #2 of 3 Old 10-24-2011, 12:05 PM
Brown Dog
Vendor
Brown Dog's Avatar
You need to find someone in the aircraft or marine welding business. Someone who really knows how to deal with cast aluminum. Welding those is pretty tricky, but can be done by the right person. Cost? No idea.
JB Weld? You would have to get it REAL clean and not have any seepage during the repair. That might be difficult.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #3 of 3 Old 10-24-2011, 12:40 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Either way, you are going to have to remove it.
If you try the JB Weld option, make sure it is clean, dry and sanded down. Also be sure that all motor transmission mounts are in tip top shape.
I would try to call around your area and see who can weld cast aluminum before though, as well as maybe trying to find one to replace it with.
http://www.ebay.com/itm/Jeep-Wrangle...item19c9f93a24
Just search for AX5 tail housing etc.
Be a good time to upgrade to a set of the above posters mounts IMHO.
And no, they are not known from cracking there as a rule.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
Buy cracked t-case? DustinHalstead TJ Wrangler Technical Forum 11 03-09-2011 04:23 PM
Transmission case cracked - 700R4 ConroeTJ TJ Wrangler Technical Forum 5 11-19-2010 01:34 AM
95 YJ 2.5L 5spd with cracked transmission case. gejinks YJ Wrangler Technical Forum 0 05-09-2009 09:41 PM
95 YJ 5sp 2.5l cracked transmission case gejinks YJ Wrangler Technical Forum 0 05-09-2009 05:22 PM
Bent rear diff and cracked transfer case, what diffs and case will bolt into my 87 YJ hillside250 YJ Wrangler Technical Forum 9 01-08-2009 01:45 AM
