95 YJ 4-banger idle question - JeepForum.com
post #1 of 2 Old 02-19-2012, 02:27 PM Thread Starter
castorriver
My fuel injected 4 cyl engine always starts and always runs good, but after the engine is hot it doesn't idle smoothly. About every 5 seconds or so the idle rpm's dip about 50-100 rpm's then goes back up to normal idle. It does this consistently. According to the tach, normal idle is about 900 rpm's.
In the past few thousand miles I've replaced the fuel filter, plugs, wires, dist cap, air filter and nothing changed-same as before the tune up. I always use napa parts.
Would cleaning the fuel injectors help? I ran a can of sea foam on my last full tank of gas.
Registered Nurse Jeep Club Member #1 (I think...)
Verse 36: And He said to them, "But now, whoever has a money belt is to take it along, likewise also a bag, and whoever has no sword is to sell his coat and buy one.
castorriver is offline
post #2 of 2 Old 02-21-2012, 12:01 AM
dilligaf69
Sounds like you need to clean up the IAC (Idle Air Control motor), it's on the throttle body. Get some good carb/throttle body cleaner and a old tooth brush and go to town. While you're in there, clean up both sides of the throttle butterfly and check for vacuum leaks, especially on any of the plastic hard lines.
Dent, what dent.... That's not a dent.... that's a good memory.
dilligaf69 is offline
4 banger with LOTS of problems (Idle, backfire,...) SDGBASSE YJ Wrangler Technical Forum 13 03-08-2010 06:59 PM
4 banger question wolfen TJ Wrangler Technical Forum 12 06-03-2009 09:43 PM
4 banger pulley question Sh4dowRac3r TJ Wrangler Technical Forum 8 05-12-2007 01:05 PM
Rebuilt 4 Banger Question Seth6815 YJ Wrangler Technical Forum 15 05-09-2005 09:37 AM
4 banger question jeepthing2000 TJ Wrangler Technical Forum 12 12-02-2004 04:30 PM
