95 yj 4.0L losing power - JeepForum.com
post #1 of 4 Old 06-14-2013, 11:29 AM Thread Starter
Devo04
Ok so i am working with a 95 yj with the 4.0L high output. and it is really losing power. it seems fine if your just cruising at slow speeds but if you come to any size of a hill the power just drops. you need to have the petal to the floor just to maintain speed and even then you are not seeing anymore the 2000 rpm. so far we have replaced the air filter, the fuel filter, and all spark plugs. what could be the cause of this issue.
Devo04 is offline
post #2 of 4 Old 06-14-2013, 11:48 AM
superj
clogged exhaust?
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 4 Old 06-14-2013, 02:22 PM
Siva283
Were the diffs regeared for the 33's? If not that could explain it.
Ask me how I know...
Siva283 is offline
post #4 of 4 Old 06-14-2013, 02:49 PM
idaholtby
Has your rig run fine in the past and this issue is new and not related to any other mods? Sounds like a clogged catalytic or fuel delivery issue if this just showed up on it's own.
Check for codes, check fuel pressure at the fuel rail, and then thump the cat and listen for a rattle (when cold of course).
idaholtby is offline
