95 YJ 2.5 Auto Shifting issues - JeepForum.com
post #1 of 15 Old 12-24-2013, 10:56 AM Thread Starter
Akiepper
When the trans shifts from 1st to 2nd it revs up to 3500 to 4000 rpm then shifts it will drive around 30 to 35mph and scream at 3000rpm for a short time before shifting. I changed the trans fluid and filter about 700 miles ago with valvoline ATF4 full synthetic and this issue just started. I checked fluid levels and all are good. I adjusted the Tv linkage to the tranny tight then loose then right in the middle no luck. Help this is annoying the crap outta me!!
Akiepper is offline
post #2 of 15 Old 12-24-2013, 11:28 AM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Sounds like a vacuum line came off.
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #3 of 15 Old 12-24-2013, 12:21 PM
jokerchief462
Find the modulator valve. Vacuum line or bad valve.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 15 Old 12-24-2013, 12:52 PM
rshbutch
There is no modulator valve on a torque flight transmission. Adjust bands or rebuild it
rshbutch is offline
post #5 of 15 Old 12-24-2013, 12:53 PM
rshbutch
And torque flights like ORMOND fluids
rshbutch is offline
post #6 of 15 Old 12-24-2013, 12:54 PM
rshbutch
Oem
rshbutch is offline
post #7 of 15 Old 12-24-2013, 01:01 PM Thread Starter
Akiepper
What do you mean oem? Where do you get ormond fluids and which one do you recomend? I might try to adjust the bands and swap fluid soon. There was a small vac line off that goes from fuel rail down to another part. I'll take some pics. Anyway I slid the line back in the boot is that ok or do they need to be sealed?
Akiepper is offline
post #8 of 15 Old 12-24-2013, 01:06 PM Thread Starter
Akiepper
Another question should I disconnet the bat to reset the computer or that won't change a thing?
Akiepper is offline
post #9 of 15 Old 12-24-2013, 03:32 PM
rshbutch
ORMOND is a miss type....lol. o.e.m is original equipment manufacturer
rshbutch is offline
post #10 of 15 Old 12-26-2013, 06:58 PM Thread Starter
Akiepper
Well adjusted the bands both front and rear and there is no change what so ever. Still revs up from second to third.
Akiepper is offline
post #11 of 15 Old 12-26-2013, 07:13 PM
rshbutch
What does fluid look like and does it smell burnt?
rshbutch is offline
post #12 of 15 Old 12-27-2013, 07:05 AM Thread Starter
Akiepper
Fluid was brand new no burnt smell. I'm taking it to the trans shop Monday to see what they say.
Akiepper is offline
post #13 of 15 Old 12-27-2013, 07:18 AM Thread Starter
Akiepper
It revs up trying to coming out of second not 1st to 2nd as I wrote before.
Akiepper is offline
post #14 of 15 Old 12-27-2013, 09:03 AM
rshbutch
I don't believe synthetic transmission fluid is compatible with the older torque flights
rshbutch is offline
post #15 of 15 Old 12-27-2013, 09:18 AM Thread Starter
Akiepper
I thought about doing something different (fluid) but I didn't. I wish I would have now.
Akiepper is offline
