'95 XJ M/C & Booster - JeepForum.com
post #1 of 8 Old 05-11-2008, 11:25 PM Thread Starter
timatoe
timatoe's Avatar
I read through a bunch of threads talking about using Master Cylinders from '95 YJ's and even some using TJ M/C. Anyhow didn't see anything about XJ's. I know a guy that's parting out a '95 XJ and about the only usable thing left is the MC and I could probably get it cheap. Just don't know if it would work. Anyone done this???
Thanks
timatoe is offline
post #2 of 8 Old 05-12-2008, 10:54 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
i think when i looked, they are the same except for the mounting arm to the pedal.
rob used an xj booster IIRC, and didnt have any issues that a sawzall and a mig couldnt cure!!
may just have to either shorten or lenghen the rod that goes to the pedal.
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 8 Old 05-12-2008, 07:13 PM Thread Starter
timatoe
timatoe's Avatar
Thanks Martin.
timatoe is offline
post #4 of 8 Old 05-12-2008, 07:22 PM
ghost183
is it any stronger than the 95 YJ? or even the older ones?
is it dual diaphram?
i would imagine the dual diaphram 95 YJ would be, but i have the opp for a XJ setup too and didnt think of it till i just saw this post
inquiring minds wanna know.......
ghost183 is offline
post #5 of 8 Old 05-12-2008, 11:10 PM Thread Starter
timatoe
timatoe's Avatar
It's definately a dual diaphram, I could tell just by how thick it was. I didn't even think to ask about the MC while I was there, but I got a complete D30 for $50 so gotta imagine it would be relatively cheap. I don't know about better than the YJ though, thing is around here I never see anyone parting out a YJ and if I do everything must be plated with gold based on the prices.
timatoe is offline
post #6 of 8 Old 11-27-2008, 03:25 AM
dukegnarley
hate to revive an old thread but i used a '99 xj booster and MC on my '88. The rod on the xj booster needs to be lengthened. the end of it is also different and won't work with the stock brake light switch. what i did was cut the end off of the xj booster and threaded the rod. I then cut the rod off of the yj booster and drilled and tapped it. I just screwed the yj end onto the xj rod. The only other problem i had was that the XJ booster is angled up and will hit the hood when it's closed. I just used a couple of washers on the top two holes in the booster to angle it back down a bit.
the difference in braking was night and day. It's totally worth it. Of course i got the xj booster and MC for free, it would be MUCH simpler to get the '95 yj one.
Unlimited Length YJ "Sasquatch"
Renix 4.0
AW4 swap with
= DONE
dukegnarley is offline
post #7 of 8 Old 11-27-2008, 04:52 AM Thread Starter
timatoe
timatoe's Avatar
Thanks for the input. I saw this on the front page and thought "WTF, I didn't start a new thread".
I ended up not getting the one I was thinking about, still on the hunt.
timatoe is offline
post #8 of 8 Old 11-27-2008, 11:30 AM
leftlanetruckin
XJ on 37's
ye see them for the 95yj's from time to time mate!
keep lookin!!
martin
Bad break booster? YJake YJ Wrangler Technical Forum 3 09-08-2009 02:58 PM
97 TJ Booster into 92 YJ djfred YJ Wrangler Technical Forum 5 04-14-2008 05:48 PM
Brake booster Bad? Devildog985 YJ Wrangler Technical Forum 14 08-29-2007 08:21 PM
Brake Booster ionakana YJ Wrangler Technical Forum 1 09-28-2006 09:08 AM
Brake Booster?? CarsonKetrowYJ YJ Wrangler Technical Forum 2 07-10-2006 10:07 AM
