'95 Wrangler YJ Rear Axle Issues - JeepForum.com
post #1 of 5 Old 07-22-2010, 07:22 PM Thread Starter
branton
Gears stripped on my rear axle. New to working on Jeeps...so extremely stupid to these things. I've doen some research and realized that the Dana 35 on there is crap. Should I/can I replace the 35 with another model for a YJ? Also, I was looking to putting a 3" lift on the Jeep anyway, so would that change the rear that I need? Thanks!
branton is offline
post #2 of 5 Old 07-22-2010, 07:24 PM
cubewhiz
You should look for a (much stronger) Ford 8.8 axle. There is a ton of information about it if you search for it. It will not affect the rear springs you need.
95 YJ with V8 going in, BDS 3.5" lift with MORE 5/8" boomerangs
Toyo Open Country M/T 33x12.50R15 on Cragar Soft 8 15x8 wheels
My new Jeep: 95 ZJ with 4.0L I6 (auto trans)
cubewhiz is offline
post #3 of 5 Old 07-22-2010, 07:30 PM Thread Starter
branton
Researching now...thanks for the heads up!
branton is offline
post #4 of 5 Old 07-22-2010, 07:44 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
check out ecgs for a bolt in 8.8.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #5 of 5 Old 07-22-2010, 07:54 PM
cubewhiz
That's where I got mine. Just about finished with the install--just need to hook up the brake lines and tighten everything up.
cubewhiz is offline
1995 , jeep , rear axle , wrangler , YJ
HELP!! Rear Axle/Suspension Issues. Need Suggestions!! Mdjeep95 YJ Wrangler Technical Forum 4 01-27-2010 02:53 PM
2003 Jeep Wrangler Rear Axle VaLoRiaN TJ Wrangler Technical Forum 3 05-05-2007 09:26 PM
rear axle issues benvh TJ Wrangler Technical Forum 15 11-26-2006 01:40 PM
2001 Wrangler rear axle wobble thecabin TJ Wrangler Technical Forum 2 06-14-2004 06:33 AM
Compatable rear axle for 88 wrangler mstcoasty YJ Wrangler Technical Forum 7 04-23-2003 12:06 AM
