95 Wrangler Yj, need help!! Runs funny!! - Page 2 - JeepForum.com
post #16 of 16 Old 07-13-2010, 08:39 AM
Que89YJ
The 2 sensors for the ignition spark are the crank sensor and the pickup sensor in the distributor. Since you know your losing spark and the crank sensor is good then its easy from here. Check to make sure you have power on the coil the next time it happens. If you have power on the coil and no spark then its after the coil and before the plugs in your ignition system. The pickup sensor in the distibutor, coil, or the distributor itself.
Que89YJ is offline
Wrangler has poor heat and runs cool RednekWrangler YJ Wrangler Technical Forum 50 10-24-2013 03:55 PM
CL Funny Wrangler 1997_Sport Wrangler General Discussion 11 12-03-2009 11:28 PM
98 Wrangler runs out of gas twhite7591 TJ Wrangler Technical Forum 8 06-06-2009 02:48 PM
Replaced fuel injectors and TB, runs funny YJInterceptor YJ Wrangler Technical Forum 7 05-23-2009 03:58 PM
1989 Wrangler 4.2 pings, runs rough rjlee38 YJ Wrangler Technical Forum 3 07-06-2007 02:55 AM
