09-07-2006, 10:14 AM
#1
"95" wrangler turn signal switch
Does anyone know how to replace a turn signal switch? What's involved?
09-07-2006, 12:00 PM
#2
Im in the same boat... have you even found the switch yet ??
Because I havent .. !!
haha
I cant even get the steering wheel off..
93' YJ [COLOR="green"]Sahara[/COLOR] "[COLOR="Red"]LIFTED-LOCKED[/COLOR]"
My [COLOR="Green"]$300[/COLOR] Jeep
"MONEY PIT"
[COLOR="Yellow"]4" [COLOR="Blue"][COLOR="Blue"]BDS[/COLOR][/COLOR], 2" BL, 35" MTR, Aussie Front/Rear, 4 100w Daylighters, HID Lamps, 9000lbs 100ft Winch.[/COLOR]
[COLOR="Blue"]http://s50.photobucket.com/albums/f327/namesmud/[/COLOR]
09-07-2006, 12:15 PM
#3
First you need a steering wheel puller, this lets you remove the steering wheel.
Then there is usually a metal lock plate (not sure if the YJ's have this or not as I have yet to remove my steering wheel) that needs to be removed. Some of them are just screwed on, others are pressed on and need a special tool to remove that as well.
The turn singal cancel switch should now be exposed and will be held in place by two or three screws.
Sometimes you have to remove the whole assembly (this includes the wiring harness for the steering wheel) as one piece to fix the problem, other times (depending on the style of the cancel cam) you can just replace parts of the cancel cam unit (ie GM vehicles).
Unfortunatetly this is kind of a generic over view of removing/replacing those parts. As I have yet to do it on my YJ I couldn't tell you exactly how to fix your problem. Hopefully someone with more knowledge can tell us something.
His: '96 ZJ, 5.2 Limited, stock, Maxxis Bighorns, '703 Injector Swap
Daily Driver: '05 SRT4, Stock turbo, 252 WHP, 321 FTLBS.
Hers: '03 WJ, 4.7 V8, Kolak Exhaust, IRO 3", JKS TB, KOR TB Bushings, 32" Cooper ATP's.
09-07-2006, 01:40 PM
#4
Do you need a flasher or the actual switch in the steering column? Flasher is on the fuseblock, extreme right side next to the pedals. Big round thing (the one on the right), I want to say ~$10?
09-11-2006, 02:54 PM
#5
turn signal switch
$$$$$$$$$ 140.00 $$$$$$$$$$ at the dealer.
09-11-2006, 03:01 PM
#6
Make it Mopar or Surplus City Jeep will have what you need.
There are a couple more but I can't think of them right now. Also, if you are going to be working on your own heep, get a FSM for your year YJ. It'll save you a TON of time and money in the long run. Good luck
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
09-11-2006, 03:29 PM
#7
my turn signal lever busted off the other day after what - 16 odd years... I think that it was about $9 from NapaOnline - the entire switch/spring/return unit is roughly $65 to $85 depending on the design of the one you're trying to remove.
I have yet to rent the steering wheel puller from my local Schucks
09-11-2006, 04:24 PM
#8
Although this link is really to fix the sloppy tilt column, it has detailed instructions on taking the steering column apart to get to that very switch.
http://www.epiccomputer.com/dale/jee...tilt/tilt.html
To answer the question earlier stated... yes, the YJ has a lock plate. You will need at least a steering wheel puller. You also need the lock plate removal tool. (More specialty tools to add to that drawer of tools you'll only use twice in your life).
1989 Jeep Wrangler - 4.0 swap, 32" BFG M/Ts, RC lift
1997 Acura 2.2CL
2008 Honda CBR600RR Graffiti Edition
09-13-2006, 09:46 AM
#9
Turn signal switch
Thank's for everybodys help.............
