95 Wrangler, runs funny! Need Help! - JeepForum.com
post #1 of 11 Old 07-12-2010, 10:06 AM Thread Starter
brittpaige15
I bought a 95 wrangler that was said to have been sitting for 8mths+ and it's fuel injected but would still turn over so I at first had no concerns. Well we got it home put a new battery in it and drained the tank and put new gas in it. Went through all the fuses and it still wouldn't crank. We have since changed the coil, cam shaft sensor, crank shaft sensor, the thing inside the distributor (forgot what its called), it at first would turn over a flood out then we changed all those, now it will crank we had it going down the road it started acting funny and it cut off, we got it to crank back quite a few times and go about 10 feet then cut off, with us trying to get it home this way we burnt up the starter, have since then changed that and towed it home. We changed it and it started right up and we just cut it off the other day we went to crank it and it wont start again you can smell gas like its flooding out but doesn't do that all the time.. I'm at a stand still with this thing. The only other thing I knw to change under the hood is the ecu and engine harness. Does anyone have any suggestions about this at all?
brittpaige15 is offline
post #2 of 11 Old 07-12-2010, 10:25 AM
sloan74
Reads like its not ECU/electrical though.
Are there any error codes stored in the ECM?
I would find that gas leak/small and go from there. It's fuel related sounds like.
If the smell is coming from the rear/underneith the jeep etc, I would start by diagnosing the fuel pump, make sure it's working properly, and check the fuel filter - yeah 8 months sitting I would definitely replace that fuel filter (even if that's not it). The filter is rear driver side up behind the tire well, you cannot miss it. The pump is right on top of the fuel tank. Unplug the line at the fuel filter leading towards the engine and see if a good constant flow of gas is coming out, etc. Dump the fuel in a oil catch/pan or something and inspect it. That filter might have all kinds of crap in it and be clogged maybe.
sloan74 is offline
post #3 of 11 Old 07-12-2010, 10:29 AM Thread Starter
brittpaige15
The fuel pump is working fine and we changed the filter. I had talked to another guy who said his jeep did it and it was his ecu going bad and it did it for four months because it was sending the wrong thing out. I ordered a new ecu off ebay and hoping it would be here today or tomo. We had someone check the fuel pump and they said it was in great working order, the filter def needed changing so we got a new one. Once it gets running it runs out great but sometimes it has spark and sometimes it doesn't.
post #4 of 11 Old 07-12-2010, 10:33 AM
sloan74
ahh ok.
Could be computer related then.
If you get it cranked again do not drive it. Just let it idle maybe for awhile. Like 10-15 minutes. Maybe longer. What did the throttle body look like?
8 months+ is a long time. If the seller told you at least 8 months, then count on it being a lot longer than that, hehe.
sloan74 is offline
post #5 of 11 Old 07-12-2010, 10:37 AM Thread Starter
brittpaige15
I am hoping it is the computer after I spent all that money. lol but okay so 10-15 min should help? We have crank it quite a few times but haven't really let it sit for that long.
post #6 of 11 Old 07-12-2010, 10:40 AM
sloan74
Yeah man let it sit and run. Give it some slight gas after awhile. But I would let it run for awhile in neutral/idle for sure. Let it try to clean all that crap thats been sittting for 8+ years off the injectors perhaps. Do you have any fuel injector cleaner? Maybe some Lucas Oil or something?
sloan74 is offline
post #7 of 11 Old 07-12-2010, 10:49 AM Thread Starter
brittpaige15
Yeah we put some lucas in it but it hasn't ran long enough to get good and in there..
post #8 of 11 Old 07-12-2010, 01:22 PM
Que89YJ
Check for faults using the Check engine light. Does the check enigne light come on when your first cycle the key to start it? When you check the fuel pump, how did you check it? The way it should be checked is with a pressure guage on the fuel rail and jumper the fuel pump relay. The pumps sometimes fail after they start to warm up.
Que89YJ is offline
post #9 of 11 Old 07-12-2010, 01:26 PM Thread Starter
brittpaige15
We had a guy come out and check it. I am not sure how he did it to be honest. And I haven't really paid to much attention. Will it come on then go right back off once it has started up?
post #10 of 11 Old 07-12-2010, 01:27 PM Thread Starter
brittpaige15
And when it floods out is when it's not started up. It doesn't do it when it get crunk. But if it won't start right off then it floods out.
post #11 of 11 Old 07-13-2010, 06:58 AM
Que89YJ
I need to get what your saying strait. Itsflooding out when its not starting. When yopu are not starting you have no spark at the plugs?
Que89YJ is offline
95 Wrangler Yj, need help!! Runs funny!! brittpaige15 YJ Wrangler Technical Forum 15 07-13-2010 07:39 AM
CL Funny Wrangler 1997_Sport Wrangler General Discussion 11 12-03-2009 10:28 PM
98 Wrangler runs out of gas twhite7591 TJ Wrangler Technical Forum 8 06-06-2009 01:48 PM
97 jeep wrangler runs poorly in the morning bkfranklin22 TJ Wrangler Technical Forum 1 05-27-2009 08:59 AM
Replaced fuel injectors and TB, runs funny YJInterceptor YJ Wrangler Technical Forum 7 05-23-2009 02:58 PM
