95 wrangler, need advice - JeepForum.com
post #1 of 3 Old 07-12-2010, 10:36 PM Thread Starter
Jared325
Damn I wrote this out once and it did not post for some reason:
I'm about to buy a 95 YJ with a carburated 350 small block and turbo 350 transmission. Apparently the engine was rebuilt 6 years ago. 4 wheel drive works, however I'm not sure if he kept the transfer case or changed that also. The body is in excellent condition for a 95. Small rust spots on LF fender and rear door. No rust on interior at all. The price is the best part, $1500.
My first upgrade I am planning on would be the axles. It still has the stock jeep axles in it. I have an 88 Blazer K-5 with a good drive line, brand new American Racing wheels, and 33x12.5 inch tires. I was wondering if it is possible to change out the entire axle housing from blazer to jeep. If not what are some good fairly cheap axles to swap out in there. I am a mechanic and I do have access to a shop, so I can do most of the work. Any suggestions or advice are welcome!!
Jared325 is offline
post #2 of 3 Old 07-12-2010, 10:47 PM
moonshinefuel
I think anything is possible. What is the width on the K-5 axles, full? I like it, I say if it is doable, then use those axles from the k-5.
moonshinefuel is offline
post #3 of 3 Old 07-12-2010, 11:05 PM
MJMPC
Or dana 30 front ford 8.8 rear
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
Advice on a wrangler blue176 TJ Wrangler Technical Forum 4 10-24-2008 10:03 PM
New Wrangler Advice? goldenjeep17 JK Wrangler Technical Forum 6 09-08-2007 12:08 PM
Looking for advice on a Wrangler... skavs165 JK Wrangler Technical Forum 25 09-26-2006 03:38 PM
about to buy an 04 wrangler, need advice Tobey TJ Wrangler Technical Forum 54 04-16-2004 09:38 PM
Newbie needs Wrangler advice hoodigah TJ Wrangler Technical Forum 13 06-15-2003 07:22 PM
