95 Wrangler 4cyl Sludge in Overlfow Tank, 120K miles - JeepForum.com
post #1 of 3 Old 04-30-2009, 01:51 PM Thread Starter
gejinks
I just had a new radiator (OEM), hoses, thermostat, etc about 200 miles ago. Today, I noticed a small amount of brownish sludge floating in the top of the coolant in overflow tank. Coolant in radiator looks fine. I changed oil last night to see if there was coolant in it and there was not. Could this just be some sediment, etc that had built up in the engine cooling passages that made it to the tank? Should I remove the tank and wash it well and then refill. I don't want to think that it is a cracked head or block.
Thoughts?
gejinks is offline
post #2 of 3 Old 04-30-2009, 02:06 PM
mgramann
Listen for gurgling after you turn the car off and check the oil for coolant to verify you don't have a headgasket, block, head problem. Sediment is common over time. A flush wouldn't hurt
mgramann is offline
post #3 of 3 Old 04-30-2009, 05:00 PM
sprowley
Sediment is common after as many miles as you have, as mgramann said, but I also agree you should double check you don't have an internal oil leak somewhere, without seeing photos of it that sounds like a possibility as well.
92 YJ Islander Sold!
97 TJ Sport black on black with MT/R Kevlars and lots of new parts coming!
Canon EOS-1D Mark III, Canon EF 70-200mm f/2.8L USM, Canon EF 17-35/2.8L USM, Sigma 50mm f/2.8 EX USM
sprowley is offline
2300 miles in a 4cyl jeep... Kastraelie YJ Wrangler Technical Forum 41 03-31-2014 06:16 PM
Is there any difference between a 91+ 4cyl and 6cyl gas tank? YeepieJeepie YJ Wrangler Technical Forum 8 06-02-2009 11:17 AM
where can i buy a new 91 4cyl fuel tank bockwho YJ Wrangler Technical Forum 1 05-25-2007 03:12 PM
Whats the value of 80k miles 97 4cyl wrangler? 4.0v8eater TJ Wrangler Technical Forum 6 04-13-2006 10:33 AM
10 gals of gas and 115 miles??? Stock 4cyl AWILD YJ Wrangler Technical Forum 5 06-12-2004 05:26 PM
