'95 steering hard then easy? - JeepForum.com
post #1 of 9 Old 04-25-2013, 05:41 PM Thread Starter
wagnergear
Hi, I have a '95 YJ 4 cyl 5 speed, new power steering pump. The steering goes from hard to turn to super easy. Any things to check? Thank You
wagnergear is offline
post #2 of 9 Old 04-25-2013, 06:14 PM
OKwranglerYJ
Mine did that for a while, come to find out it was my front axle U-joints.
OKwranglerYJ is offline
post #3 of 9 Old 04-25-2013, 09:39 PM
609thomasm
Just had the same problem last week, steering was hard then easy thru every turn of the wheel. Almost like something was bent. Found out it was the steering shaft u-joint where it connects to the column at the firewall. U-joint was very stiff, almost seized. Removed shaft and worked some WD-40 into it and also un-seized the two halves of the shaft so it would slide in and out on itself and reinstalled and steering worked smooth as silk. Good Luck
609thomasm is offline
post #4 of 9 Old 04-26-2013, 05:37 AM
Siva283
Does it whine when it is hard to turn?
Ask me how I know...
Siva283 is offline
post #5 of 9 Old 04-26-2013, 06:04 AM
Louie4
You could always change the power steering fluid if all else fails.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #6 of 9 Old 04-26-2013, 09:14 AM
instg8tor
X2 on the steering shaft ujoint and slip. It should be the first thing you do in troubleshooting the issue because it's so easy to do.
Mine had the same symptoms. heavy dose of lube and steering was smooth again.
'91 Renegade - Waggy 44/20 (F/R Aussie) SOA, E350 MC, York OBA, Custom F/R bumpers
instg8tor is offline
post #7 of 9 Old 04-26-2013, 09:59 AM
bogleparsons
you guys and your silly "power" steering.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #8 of 9 Old 04-26-2013, 11:41 AM
Que89YJ
Check the lower bearing and the ujoint on the steering column. My bet is the Ujoint is bad.
http://www.jeepforum.com/forum/f12/l...t-pics-741968/
http://www.jeepforum.com/forum/f12/h...-pics-1147424/
Que89YJ is offline
post #9 of 9 Old 04-27-2013, 06:22 AM Thread Starter
wagnergear
Thanks for all the help and links. Tom
