95 Rio Grande (Build) Taking her all apart - JeepForum.com
post #1 of 33 Old 11-01-2009, 10:49 PM Thread Starter
jackster1797
Well I have only been a member here for a short time but I am going crazy my buddy is stripping down my jeep and is swapping my 95 4cyl for a 95 Inl6 the donor vehicle is just what it is all that it has is the frame, partial tub and a supped up engine from the 150 dollar plug wires and distributor to the headers and cherry bomb exhaust the guy who had this jeep before me was fixing the engine up till he just ran out of money and the know how to remove it once he found out that his frame was shot I am also painting my jeep (Color Scheme Light brown basecoat with a dark brown metalic overcoat smeared with seran wrap to give it a marblized look) I will continue to post pics from now till Jan that is the supposed time of completion or should I say this upgrade lol thats my SGM buddy from Ft.Drum driving the Donor!!!!!
jackster1797 is offline
post #2 of 33 Old 11-02-2009, 01:05 PM Thread Starter
jackster1797
Will the fuel pump in a 4cyl work with the Inl6 or will I have to switch them out
post #3 of 33 Old 11-02-2009, 01:55 PM
1997_Sport
Looks good, I will be watching this build til its done.
1997_Sport is offline
post #4 of 33 Old 11-02-2009, 03:02 PM
provinT13
Yes 2.5L fuel pump will work with a 4.0
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #5 of 33 Old 11-03-2009, 01:18 AM Thread Starter
jackster1797
Cool thanks for the help my understanding is that the fuel lines and the motor mounts are the only thing I will need to replace on this swap. Motor mounts I dont really have to but its my pefered choice but everything else should go right in and I have all the major donor parts I do have to find a radiator fan shroud that should'nt be to hard
post #6 of 33 Old 11-03-2009, 01:27 AM
Opihi59
from here it gets rough
Opihi59's Avatar
The wiring harness is different of course, as is exhaust, etc. You should be able to swap everything over though since you have a full donor. You'll find a variety of things that weren't quite expected though but if you're down at the MWR auto hobby shop, you'll find help. You can purchase new motor mounts to weld to the frame, just measure their location out from your donor and transfer to the recipient frame and weld them in. You will be replacing the entire drivetrain though, right? 6 cyl with the AX15 and NP231 as a single unit. You should be able to sell your AX5 and the NP231 that came with it.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #7 of 33 Old 11-03-2009, 01:57 AM Thread Starter
jackster1797
Is that the under the hood harness the donor is a 94 and my jeep is a 95 I know all the under the wiring needs to be swappped out but thats it right also the donor vehicle has a cherry bomb exhaust that is aftermarket what are your comments on this....
post #8 of 33 Old 11-03-2009, 02:24 AM
Opihi59
Opihi59's Avatar
Having not done a 4 cyl to a 4.0 swap, I am not certain of the specific details of what wiring can be retained, etc. The ECU will be different.
You may find the Cherry bomb to be uncomfortably loud, the rest of the tubing from the 4.0 should be able to swap over unless it is in sorry condition.
Opihi59 is offline
post #9 of 33 Old 11-07-2009, 12:10 AM Thread Starter
jackster1797
Updated Pics of donor jeep. Should be removing both motors sometime starting Mon long way to go but will be worth it come Jan when she has the 4.0 and a fresh paint job will post more pics when they are both completely out of the jeeps
post #10 of 33 Old 11-10-2009, 10:55 PM Thread Starter
jackster1797
Well both motors are out
Took Tub Off the Donor
Taking the 4cyl OUT!!!!
Inline 6 OUT
Inline 6 Going IN
So she is coming along good can wait to get this fininshed and move on to the paint job
post #11 of 33 Old 11-11-2009, 05:04 AM Thread Starter
jackster1797
Well Like I said she is coming along cant wait to get the engines finished to move on to the Paint Job
post #12 of 33 Old 11-11-2009, 10:21 PM Thread Starter
jackster1797
Welding in the engine mounts
Well Engines in time to start hooking everything up and preparing for the first start up
post #13 of 33 Old 11-12-2009, 10:53 PM Thread Starter
jackster1797
Ok my jeep was a Inline 4 I now have a Inline 6 since my jeep was a standard I am guessing I have the 4.10:1 gears and if so, is that good for the Inline 6 and should I be running 35's or 33's what do you think guys...
post #14 of 33 Old 11-12-2009, 11:48 PM
Opihi59
Opihi59's Avatar
You should do fine with 33s on your 4.10s. your 4" lift is right for 33s as well.
Fast work on that swap.
Opihi59 is offline
post #15 of 33 Old 11-13-2009, 12:12 AM Thread Starter
jackster1797
Well I cut my fender wells out to be able to accept 35's just in case I was going to go that route but thanks for the info....Paint should be coming soon as well
My Rio Grande Build biggn235 YJ Wrangler Technical Forum 78 10-31-2012 07:09 PM
95 Rio Grande Before / After alandchris YJ Wrangler Technical Forum 17 08-27-2007 01:21 PM
rio grande vs se XJ99RedNY YJ Wrangler Technical Forum 4 01-14-2006 04:45 PM
Rio Grande 95_Rio_Grande YJ Wrangler Technical Forum 1 08-24-2005 08:56 AM
Rio Grande sammykitch YJ Wrangler Technical Forum 2 06-17-2005 03:02 PM
