95 Rio Grande AX-5 Transmission Question - JeepForum.com
post #1 of 12 Old 04-06-2010, 03:51 PM Thread Starter
Eric78
I am rebuilding a 95 ax5 and I am having trouble identifying a part that magically appeared on the bench during shifter rod removal. Is there a short round ended needle bearing in one of the holes that have the spring & ball bearing?
Eric78 is offline
post #2 of 12 Old 04-07-2010, 07:23 AM Thread Starter
Eric78
so I take it that nobody knows or they dont understand the question
Eric78 is offline
post #3 of 12 Old 04-07-2010, 10:14 AM
ecaps
It's difficult to figure out exactly what part is in question. Can you possibly post a pic.
Otherwise, below is an exploded view & description of the AX-5 transmission. Can you find your "mystery" part?
1 Boot
________________________________________
2 Bushing, Shift Lever
3 Case to Extension Housing Gasket Also need 52152 01
3 Case to Extension Housing Gasket Also need 52152 02
4 Shifter Housing Gasket
5 Shaft, 3rd & 4th Shift AX5
6 Shaft, 1st & 2nd Shift 1984-99
7 Shaft, Reverse Shift 1988-99, AX5
8 Shaft, 5th Gear Shift 1987-99, AX5
9 Shaft, Reverse Gear 1984-99
10 Fork, 5th Gear Shift 1987 - Apr 1, 1993
11 Fork, Reverse 1984-99
12 Fork, 1st & 2nd Shift 1990-99
13 Fork, 3st & 4nd Shift 1984-99
14 Seal, Front 1984-99
15 Bearing, Front 1987-99
16 Main Drive Gear (Input Shaft) 1986 - Nov 5, 1988 (except diesel)
Main Drive Gear (Input Shaft) Nov 6, 1988-1999
17 Ring, 3rd & 4th Blocking 1984-99
18 Needle Bearings (Need 14), (Input Shaft)
19 Springs, Synchronizer - 3rd & 4th 1984-99
20 Hub, 3rd & 4th synchronizer 1984 - Nov 5, 1988
Hub, 3rd & 4th synchronizer Nov 6, 1988-1999
21 Key, Synchronizer - 3rd & 4th 1984 - Nov 5, 1988
Key, Synchronizer - 3rd & 4th Nov 6, 1988-1999
22 Sleeve, Synchronizer - 3rd & 4th 1984 - Nov 5, 1988
Sleeve, Synchronizer - 3rd & 4th Nov 6, 1988-1999
23 3rd Gear 1984 - Nov 5, 1988
3rd Gear Nov 6, 1988-1999
24 Caged Roller Bearing (under 3rd gear)
25 Main Shaft 1984-99
26 Caged Roller Bearing (under 2nd gear)
27 2nd Gear 1984 - Nov 5, 1988
2nd Gear Nov 6, 1988-1999
28 Ring (2), Blocking, 1st & 2nd 1987-99
29 Spring, Synchronizer - 1st & 2nd 1984-99
30 Hub, 1st & 2nd Synchronizer 1984-99
31 Reverse Gear, 1st & 2nd slider 1984-97 XJ, 1987-98 YJ & TJ
32 Key, Synchronizer - 1st & 2nd 1984-99
33 1st gear 1984 - Nov 5, 1988
1st gear Nov 6, 1988-1999
34 Caged Needle Bearing, 1st Gear 1984 - Nov 5, 1988
Caged Needle Bearing, 1st Gear Nov 6, 1988-1999
35 Retainer, Front Bearing 1984-93 (gas engine)
36 Plug
38 Seal, Rear adapter 1984-99 AX4 & AX5
39 Bearing, Front Cluster Gear 1984-99
40 Cluster Gear - Threaded End 1984 - Nov 5, 1988
Cluster Gear - Snap Ring End 1989-97 XJ, 1989-99 YJ & TJ
41 Bearing, Rear Cluster Gear 1984 - Nov 5, 1988
Bearing, Rear Cluster Gear Nov 6, 1988-1999
42 Reverse Idler Gear 1984-97 XJ, 1987-98 YJ & TJ
Reverse Idler Gear 1998-99 XJ
43 Shaft, Reverse Idler 1984-99
44 Thrust Washer, Cluster All
45 Caged Roller Bearing, under 5th gear
46 Gear, Counter 5th 1987-99
47 Key, Synchronizer - 5th gear 1987-99
48 Spring, Synchronizer - 5th Gear 1987-99
49 Sleeve, Synchronizer - 5th Gear 1988-93
Sleeve, Synchronizer - 5th Gear 1994-99
50 Spacer, 5th Gear 1998-99
51 Ball, Reverse
52 Race, 1st Gear 1984 - Nov 5, 1988
Race, 1st Gear Nov 6, 1988-1999
53 Bearing, Mainshaft Rear 1984 - Nov 5, 1988
Bearing, Mainshaft Rear Nov 5, 1988-1999
54 5th Gear, Mainshaft 1984-99 All AX5
55 Switch, Backup Lamp 1987-99
56 Kit, Bearing & Seal Overhaul 1984-87, AX5
Kit, Bearing & Seal Overhaul 1987-99, AX5
57 Complete AX-5 Transmission 84-91 XJ and 87-01 YJ & TJ
58
Boredom is the desire for desires.
Stays crunchy ......even in milk
ecaps is offline
post #4 of 12 Old 04-07-2010, 10:16 AM
YJake
You're talking about one of the "plugs" right? The cylindrical shaped metal pieces that are placed inside the intermediate plate that hold the shift rails in place?
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #5 of 12 Old 04-07-2010, 10:59 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Jake
Yep.......he needs your pdf file to see where it goes.
Jake, please look in my "Transmission" album & see if you can see the pic I have of the vacuum hose with a magnet in it for reinstalling those. If you can post that pic in this thread.
It's a small magnet that I removed from the end of a small pocket screwdriver handle & inserted it in a vacuum hose. The pic shows it poked through one of the shift rail holes in the plate.
Thanks Jake!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 12 Old 04-07-2010, 11:15 AM
YJake
Here they are.
Originally Posted by Mean Max View Post
Thanks Jake!
Max
No problem!
Jake
/l , [____],
()_) ()_)==@=)_)
YJake is offline
post #7 of 12 Old 04-07-2010, 12:16 PM Thread Starter
Eric78
I did find where one of them goes it went in a hole in one of the shifter rails. I just cant find where the other one goes it is the same as the one that went in the rail
Eric78 is offline
post #8 of 12 Old 04-07-2010, 12:18 PM Thread Starter
Eric78
in the diagram above shifter rail #6 is the one i have already installed
Eric78 is offline
post #9 of 12 Old 04-07-2010, 12:38 PM Thread Starter
Eric78
Can someone tell me how to post a pic?
Eric78 is offline
post #10 of 12 Old 04-07-2010, 01:27 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Host it on an image site (photobucket, imageshack, etc....) and then include the link from the site that includes the image tag that looks like {IMG}url_to_image_goes_here{/IMG} but with the [ & the ] brackets instead of the { } brackets I used in my example.
Max
Mean Max is offline
post #11 of 12 Old 04-07-2010, 01:42 PM Thread Starter
Eric78
Eric78 is offline
post #12 of 12 Old 04-07-2010, 06:22 PM Thread Starter
Eric78
I found it! It was the pin in the reverse rail. It is now installed in it's proper location, and the trans will go back in the YJ tomorrow. Thanks for all the help.
Eric78 is offline
Question about Alloy USA Grande 35 wheel bearings +GRAVES+ TJ Wrangler Technical Forum 15 03-08-2009 02:44 PM
95 Rio Grande Before / After alandchris YJ Wrangler Technical Forum 17 08-27-2007 01:21 PM
rio grande tcox YJ Wrangler Technical Forum 1 08-06-2006 04:30 AM
Rio Grande sammykitch YJ Wrangler Technical Forum 2 06-17-2005 03:02 PM
Rio Grande RCHavok797 YJ Wrangler Technical Forum 5 09-28-2004 07:22 PM
