95 jeep yj transfer case noise - JeepForum.com
post #1 of 4 Old 03-21-2011, 10:40 PM Thread Starter
brehlmann
hello there i have a np231 tc and the rear yoke has play in it so i got the bearing bushing and seal i was under their and noticed that when i turn the ds it makes a clanking noise from the rear of the transfer case when you turn it side to side and when i shift i also feel it in the lower gears what could it be i haven't changed any thing yet thanks
brehlmann is offline
post #2 of 4 Old 03-21-2011, 11:25 PM
Mark455SD
1961 CJ5
Sounds like a loose chain.
Mark455SD is offline
post #3 of 4 Old 03-23-2011, 08:59 AM Thread Starter
brehlmann
Is there any way to tighten the chain or just replace it and if so should I replace any thing else wile I'm in there
post #4 of 4 Old 03-23-2011, 09:41 AM
jeepin1995
jeepin1995's Avatar
replace the chain and buy a rebuild kit for the case. they are real simple cases to tear apart/put back together.
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
drive shaft , noise , rear axle , transfer case
Transfer case noise =( monica02190 YJ Wrangler Technical Forum 6 05-08-2010 07:42 AM
transfer case noise remington1 TJ Wrangler Technical Forum 3 04-09-2009 07:31 PM
Transfer case boot for 231c transfer case in jeep wrangler kniteman YJ Wrangler Technical Forum 2 03-16-2009 01:28 PM
Transfer case noise in 4wd bradthebard TJ Wrangler Technical Forum 4 12-24-2008 07:04 AM
Transfer Case Noise 92 RED YJ IN NJ YJ Wrangler Technical Forum 3 12-18-2001 09:47 PM
