95' Jeep Wrangler OBD Location???? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 95' Jeep Wrangler OBD Location????
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 01-06-2011, 08:25 AM   #1
bigbadgrizz660
Hey Guys. I'm new to this site. This is my first post. I'm looking for the OBD reader location on my 1995' Jeep Wrangler Rio Grande. The check engine light is on, and I need to hook up my scanner. I looked under the hood and steering wheel pretty good, but can't find it. ????
bigbadgrizz660 is offline   Reply With Quote
Unread 01-06-2011, 08:44 AM   #2
Que89YJ
How to:
And this is what they mean:
http://www.jeepforum.com/wiki/index....k_Engine_Codes
Que89YJ is offline   Reply With Quote
Unread 01-06-2011, 10:48 AM   #3
bigbadgrizz660
Is there an OBD reader connector in this jeep.
Unread 01-06-2011, 10:53 AM   #4
jmmorgan82
No. Listen to the guy with the mullet in the video The link that Que posted up is a good one to read.
jmmorgan82 is offline   Reply With Quote
Unread 01-06-2011, 11:34 AM   #5
zeus87gn
Automotive Neurosurgeon
zeus87gn's Avatar
1987 YJ Wrangler
Yes, there is...at least there is on my 92.
I honestly don't know if the 95 is any different.
It's in the d/s rear corner of the engine bay, close to the computer that is mounted on the firewall.
My scan tool reads everything just fine.
Handicapped license plates are not for mentally handicapped people -
Holley Carb thread
zeus87gn is offline   Reply With Quote
Unread 01-06-2011, 11:42 AM   #6
Que89YJ
Its in the same place Zeus. If you are just looking for fault codes the the method I posted will give you the exact same codes. If you have a scan too though, you can actually look at the voltages on the sensors. It is a big advantage when you have the sensor that fails in a normal operating range and doesnt thow a fault code. You can actually see the sensor value not changing.
Unread 01-06-2011, 11:42 AM   #7
jmmorgan82
Got a pic of the location Zeus?
Unread 01-06-2011, 11:49 AM   #8
zeus87gn
zeus87gn's Avatar
1987 YJ Wrangler
I can get one later today...at work right now and lunch is almost up.
Holley Carb thread
Unread 01-06-2011, 12:16 PM   #9
Mitchness
I was about to say... with OBDI you only need to do the ignition wiggle trick. None of this "scanning" business.
Originally Posted by CopperHead_Road View Post
Then again, I live in the mountains and sip (non-taxed) corn whiskey for a living... I may not know what the heck I'm talking about... lol
Mitchness is offline   Reply With Quote
Unread 01-06-2011, 03:48 PM   #10
TSEJEEPERS
The place to hook the scanner up is in the buddle of wires above the computer on the fire wall.
Mine has a rubber plug over it.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote
