95 Fuel Lines - JeepForum.com
post #1 of 4 Old 05-30-2009, 07:39 PM Thread Starter
Mark05059
95 Fuel Lines
I removed the fule lines from the 2 plastic lines at the front of the jeep and then removed both lines completly from the tank so I could repair the frame. I now cant remember which line goes to which. I am wondering if anyone can tell me which line the fuel filter line is connected to at the front (one line has a vac line near attached near it)... Both of the attach to the fuel rail it appears.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #2 of 4 Old 05-30-2009, 07:55 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
The fuel supply tube is the one nearest the firewall on the fuel rail. The other is the return line which is closer to the radiator.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 4 Old 06-01-2009, 07:28 PM Thread Starter
Mark05059
Thanks alot!!
That was a big help. The lines went back on without any problems. <<-- On me
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #4 of 4 Old 06-02-2009, 07:08 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
QUOTE=Mark05059;7330076]Thanks alot!!
That was a big help. The lines went back on without any problems. <<-- On me[/QUOTE]
Broken Fuel Rail and Fuel Lines!!!! narnold YJ Wrangler Technical Forum 12 08-28-2013 09:34 AM
93 YJ fuel lines? DCGayhart YJ Wrangler Technical Forum 1 12-22-2008 12:35 PM
Fuel lines that connect up top to the fuel rail bigredcherokee YJ Wrangler Technical Forum 3 09-02-2008 02:05 AM
87 YJ fuel tank and lines running to fuel pump 87yjjeep YJ Wrangler Technical Forum 2 05-27-2007 03:07 PM
Need braided steel fuel lines (from tank to frame lines) drew2000 YJ Wrangler Technical Forum 4 06-18-2006 08:38 AM
