95 Dual diaphram booster/master cylinder upgrade - Page 3 - JeepForum.com
post #31 of 69 Old 05-20-2012, 06:46 AM
shoreline
1987 YJ Wrangler
Right now you can't find any 95 Boosters, they are all bought from the same source A1Cardone or something like that, and they don't have any. The parts number (54-73153) are all the same at every major parts retailer. Anyway I was actually able to find one on Ebay. So try that route also if you can't find it anywhere.
I got a new Wagner from rockauto and they appear to be in stock now. Part numbers are different than yours also - MC131400
http://www.rockauto.com/catalog/moreinfo.php?pk=1798154
shoreline is offline
post #32 of 69 Old 05-20-2012, 07:37 AM
Que89YJ
The link is to the master cylinder. Do they have the booster? It's too difficult for me to search with the cell.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #33 of 69 Old 05-20-2012, 09:17 AM
timatoe
timatoe's Avatar
Keep in mind if you can't find the '95 booster, you can make a TJ booster work too. There's a write up on here but I don't have it handy. I got the booster, MC, and prop valve from a guy with three wrecked TJ's building one good on for $35, it was actually a SUPER easy swap.
timatoe is offline
post #34 of 69 Old 05-21-2012, 04:26 AM
shoreline
1987 YJ Wrangler
oops - sorry about that. I bought the booster and master from them last year. Here is a link to the booster.
http://my.cardone.com/English/club/m...ARTNUM=5473153
And now I see the problem, the only option they offer now is to send yours in to be rebuilt
post #35 of 69 Old 05-21-2012, 08:26 AM
Que89YJ
Thanks Shoreline. Good info to add to the thread!
Que89YJ is offline
post #36 of 69 Old 05-21-2012, 08:51 AM
jbolty
jbolty's Avatar
If you put in a Cardone booster make sure they have several in stock because it usually takes a few to get one that works.
The TJ booster can be made to work fairly easily but it does require some fab skills. The push rod from the pedal is considerably shorter and the length is very specific so if it's cut and lengthened it will need to be adjustable. Also, the hole in the end needs to be drilled out to 5/8.
jbolty is offline
post #37 of 69 Old 05-21-2012, 11:02 AM
captainauti
hey there, i did the swap a month ago with a cardone, put it in, stops better, but with alot of pedal travel. what are the symptoms of a bad booster.. the pedal isnt super hard to push, and it desnt pull down on its own.
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is offline
post #38 of 69 Old 05-21-2012, 11:10 AM
Que89YJ
Captain, it sounds like you just need to adjust your linkage.
Que89YJ is offline
post #39 of 69 Old 05-21-2012, 11:34 AM
captainauti
i think its adjusted all the way. anymore starts to allow fluid to pass
Capt. Nate
aka Scallywag
post #40 of 69 Old 05-21-2012, 11:40 AM
jbolty
jbolty's Avatar
The ones I had were soft pedal and constantly feeling like it needed bleeding. The brakes would only hard stop if the pedal was all the way to the floor.
I'm not kidding about having 3 in a row that were bad, and not all from the same parts store.
Mr Blaine swapped in an OEM TJ booster for me on a custom bracket and it all work instantly.
I went through that too. If the push rod is too tight then the master can not fully release and the brakes will start to drag until you can't move. The correct adjustment is just touching, then back off about a 1/2 turn.
jbolty is offline
post #41 of 69 Old 05-21-2012, 02:36 PM
timatoe
timatoe's Avatar
Excellent point. I sometimes forget not everyone has access to things needed for something like this. A lot people may not even have a drill bit larger than a 3/8's.
timatoe is offline
post #42 of 69 Old 05-22-2012, 10:18 AM
captainauti
jus called and ordered another booster. they are bringing in 2 for me if that doesnt work, ill go tj style.
my pedal goes way down before it works then it will stop... sounds the same. thanx guys.
EDIT: no more for 95... ordering a 96 he said.... i guess ill see what comes in. lol
Capt. Nate
aka Scallywag
post #43 of 69 Old 05-22-2012, 10:31 AM
mazyj
I had read previously about A1 boosters having issues and checked around for alternatives as I plan on doing this swap very soon. Just so everyone knows the ones that NAPA stocks are listed as being made exclusively by either ATE or Bendix- both of which I would trust. This is the route I plan on doing.
91 wrangler 4.0L, 4 in Suspension lift, 1 inch Shackle Lift, 1 inch Body Lift, 35" BFG Mud Terrains, Warn Rockcrawler Front Bumper, Hand Throttle, HiLift, 12 pack of Natty Boh.
mazyj is offline
post #44 of 69 Old 05-22-2012, 12:00 PM
captainauti
yeap, but napa can only get the A1. and, they are all out. called 20 mins ago, nowhere in the system.
Capt. Nate
aka Scallywag
post #45 of 69 Old 05-22-2012, 12:15 PM
mazyj
Ah that's no good- im a very regular at the one by my house so ill run it by them and confirm just to be sure.
mazyj is offline
Brake booster and master cylinder Flingit1200s YJ Wrangler Technical Forum 12 05-30-2011 02:11 PM
Brake Booster or Master Cylinder>? MikeUnlimited04 TJ Wrangler Technical Forum 2 03-19-2010 08:42 PM
Help with Brake Booster/ Master Cylinder Tompatt YJ Wrangler Technical Forum 13 10-27-2008 02:03 PM
What years for a dual diaphram booster? Mudslide YJ Wrangler Technical Forum 3 09-26-2006 07:15 AM
brake booster and master cylinder sandman'sjeep YJ Wrangler Technical Forum 3 06-28-2006 08:51 AM
