'95 Dual Diaphragm Prop. Valve question... - JeepForum.com
post #1 of 5 Old 10-13-2015, 03:28 PM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
Hi all...
I'm in the process of installing a 1995 YJ DD brake booster/proportioning valve in a CJ5 that I'm building.
Timatoe, on this forum, was kind enough to tell me which lines on this setup go to which wheels on the jeep.
Well, I have another question. The "rear" fitting (closest to the booster) has this cap / plug installed into the threaded hole.
I thought that a brake line installed into all the output holes of the P. valve.
This looks like a factory plug. Could it be that the front brakes were only fed with one line, and used a junction block ("splitter"), like the rear brakes use?
Here are some pics...
Anybody have any experience with something like this?
Thanks.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #2 of 5 Old 10-13-2015, 04:24 PM
rustisexpected
If it is just a stock YJ prop valve then you will use the plugged hole. In the factory application there would not be a split for the front brakes.
rustisexpected is offline
post #3 of 5 Old 10-13-2015, 06:29 PM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
Thanks, Rust...
I bought this unit used, then cleaned and painted it. So...it IS stock. Why would there NOT be a line coming out of there when it was on the original Jeep?
This plug thing confuses me...
Rich
rixcj is offline
post #4 of 5 Old 10-13-2015, 08:53 PM
timatoe
timatoe's Avatar
Yeah, a line should go there. Maybe whoever had that before was using some different type of setup????
timatoe is offline
post #5 of 5 Old 10-14-2015, 02:52 AM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
OK...the consensus has it...I'm putting a front brake line there. I just wanted to make sure that there wasn't an option, here.
Thanks!
Rich
rixcj is offline
