'95-convert manual to power steering. - JeepForum.com
post #1 of 3 Old 04-26-2013, 05:42 PM Thread Starter
SpecForMedic
Hey I am a newby in working on my jeep by do have a mechanical background. My 95 Wrangler has about a 3 inch lift on it and manual steering. Id like to convert this to power steering. The Steering is extremely loose. I already upgrade the stabilizer and it still is pretty loose with some play. My questions are:
Where do i measure it to confirm the exact height of the body lift?(im guessing this affects which any arms needing to be bought).
Also, what parts do i need to buy to do this conversion?
SpecForMedic is offline
post #2 of 3 Old 04-26-2013, 06:19 PM
95-rio-pv5
Welcome to JF! You will find a lot of good helpful info here. Use the search tool to find common wright ups like engine swaps, what part from other Jeep brand vehicles will fit your YJ and ect. Just make sure you fill out your jeep info..that way it will be easier for us jeep nuts to help you. For example the 2.5 4 cylinder uses, for most years the ax5 transmission where the 4.0 and the 4.2 uses different trannys and they are not a direct bolt on. Sorry I can't help you on the power steering pump. But welcome all the same.
95-rio-pv5 is offline
post #3 of 3 Old 04-26-2013, 10:59 PM
caoboy
http://www.jeepforum.com/forum/f12/p...62/index4.html
I'm also converting mine.
You'll need to fill out your profile so we can know what is done to your Jeep.
You'll need a certain pump, depending on your motor, because the ones with the reservoirs attached won't fit a 2.5 MPFI.
You need :
Pump (either with reservoir or without) [2.5 MPFI needs a remote reservoir]
(reservoir)
Pressure line
Return line
Power steering gear box
Power Steering pitman arm
New drive belt that accommodates the PS Pulley
I believe that's it. I purchased a pump/lines/gearbox/pitman arm for 120+shipping of eBay. I'm waiting anxiously for it to show up...then I'll grab a reservoir and tackle this job.
caoboy is offline
