95 cheokee 4.0 swap can i use 94 yj harness - JeepForum.com
post #1 of 2 Old 09-01-2014, 07:06 PM Thread Starter
darrentrent
i bought a 95 cherokee 4.0 to swap into my 89 yj in place of the 4.2 the wiring has scared me a bit so havent proceeded with the swap but now have a line on a 94 4.0 yj thats being parted out so can i use the 94 underhood directly on the 95 with minimal complications and can i just swap both the underhood and dash harnesses as well as computers into my yj instead of splicing or changing pin outs on the yj? thank you for helping!
darrentrent is offline
post #2 of 2 Old 09-02-2014, 08:21 AM
Que89YJ
Yes you can. Remember the VSS will be different as will the cluster wiring so if you can get the cluster you will make your life a lot easier. If not then you will need to wire in a 91 YJ VSS
Que89YJ is online now
