95 brake booster vs 93 - JeepForum.com
post #1 of 7 Old 03-30-2009, 02:52 PM Thread Starter
brinoff
brinoff's Avatar
Just want some reaffirmation. The 95 Yj has a dual diaphram booster, right? Will I notice a difference over a the booster in my 93? Thanks.
93YJ 4.0 I6, AX-15, NP231 Teraflex SYE, Tom Wood Drive Shaft, G2 D44 ARB, ARB locked 30, T&T customs axle trusses, ProComp 35" Mud Terrain, RE SD 4" Lift, Daystar 1" BL, Harbor Freight 8000 Winch, Swing Away Tire Carrier, and some other stuff.
brinoff is offline
post #2 of 7 Old 03-30-2009, 03:31 PM
4.7stroker
Oh yea, this is one of my favorite mods.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 7 Old 03-30-2009, 03:55 PM
CjinPA
CjinPA's Avatar
Only 95 YJ's with the 4.0L motor came with the dual diaphragm booster. The 4 cylinder Jeeps still had the single diaphragm boosters. You should notice a difference with the dual diaphragm booster. I have a 95 YJ dual diaphragm booster in my CJ and it will lock up my 37" tires. You will also need the firewall bracket and master cylinder from the 95 YJ. I would also try to get the lines that run from the MC to the proportioning valve because the master cylinder takes metric thread fittings and the brake lines need to have a bubble flare on the end of them. A single flared line will also work if need be.
84 CJ7 Northstar V8
91 YJ Renegade.
I've been in this rut plenty long enough, I know what to expect. Weather my day is hell, or weather it goes well is kind of up to me I guess.
CjinPA is offline
post #4 of 7 Old 03-30-2009, 06:02 PM
Axl Jack
^ Don't listen to CjinPA. He doesn't know what he's talking about.
Just kidding. Considering he gave me one of the 95's.
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #5 of 7 Old 03-30-2009, 06:35 PM
yellow2kgt
I agree with everything said above. It ranks up their with the fuel injection as one of my favorite mods. It is nice to only have to barely touch my brake pedal to come to a quick stop.
Just like CJinPA said you will need the 95 master cylinder as well and I also used the 95 brake lines to prop valve due to the 95 master having metric threads.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #6 of 7 Old 03-30-2009, 07:07 PM
CjinPA
CjinPA's Avatar
Your funny Ross. If your never going to put the 95 dual diaphragm brake booster that I sold you in your Jeep maybe this could be a potential sale for you.
As for the difference between the single diaphragm and dual diaphragm set ups, The single diaphragm brake booster puts out somewhere around 1000 lbs of pressure. The dual diaphragm booster puts out around 1500 lbs of pressure so you get 50% more power to your brakes.
84 CJ7 Northstar V8
91 YJ Renegade.
CjinPA is offline
post #7 of 7 Old 03-30-2009, 07:41 PM
Axl Jack
Well I bought it off you before I did the 8.8 swap thinking I might need/want it. But the rear discs gave me a lot of extra stopping power. I'm still going to swap yours eventually.... probably some lazy rainy day this summer.
Axl Jack is offline
Replaced Brake Booster - now brake lights stay on Viking TJ Wrangler Technical Forum 4 04-11-2017 06:46 PM
After brake booster install, brake lights are on??? HoustonRenegade YJ Wrangler Technical Forum 6 05-17-2009 07:49 PM
TJ brake booster in my YJ? czjeeper YJ Wrangler Technical Forum 1 01-18-2009 01:02 PM
Brake Booster? camcrazy YJ Wrangler Technical Forum 7 06-25-2007 10:00 PM
Brake Booster ionakana YJ Wrangler Technical Forum 1 09-28-2006 08:08 AM
