95 bogs down while driving, please help!! - JeepForum.com
post #1 of 8 Old 04-27-2010, 07:59 AM Thread Starter
tom49329
I have the 2.5 in my 95 Wrangler, I just replaced the Alternator, water pump. and power steering pump, and belt, all was well, driving into work this morning, it was like I let off the gas, it bogged right down, so I stepped on the gas and off it went, it did this about 5 times in 20 miles, I have a 40 mile ride home, not looking forward to it, any ideas out there? This is the first time it has done this.
tom49329 is offline
post #2 of 8 Old 04-27-2010, 08:08 AM
Djsthe1
Did you notice anything odd with your gauges while this was happening?
Djsthe1 is offline
post #3 of 8 Old 04-27-2010, 08:09 AM
Que89YJ
Do a battery reset. With all the things replaced you might have stored a bad cal in the engine controller. Do a quick fault check. The method is in the FAQ. Where are you at in Michigan?
Que89YJ is offline
post #4 of 8 Old 04-27-2010, 08:12 AM Thread Starter
tom49329
Gages were all good, no drops at all
tom49329 is offline
post #5 of 8 Old 04-27-2010, 08:14 AM Thread Starter
tom49329
Thanks, I will try this for sure, Howard City
tom49329 is offline
post #6 of 8 Old 04-27-2010, 08:27 AM
Djsthe1
Yea, defiantly do a reset and check for codes. Your probably not gonna get a code for anything unless your light came on.
Djsthe1 is offline
post #7 of 8 Old 04-27-2010, 12:29 PM Thread Starter
tom49329
I did the battery reset, two codes came up, one for the Oxygen Sensor, the other for Air Conditioning, lol, dont have air.
tom49329 is offline
post #8 of 8 Old 04-27-2010, 01:27 PM
Que89YJ
O2 will bog it down. You can disconnect and it will run rich but it shouldnt bog it down as much until you get the O2 replaced.
Howard City, you are in the Manistee Forest then. Great Jeeping area all around you.
Que89YJ is offline
Went though the Mud Bogs lilred4x4 JK Wrangler Technical Forum 4 08-04-2008 03:15 PM
bogs out when taking off? 1stJeepyj YJ Wrangler Technical Forum 6 04-06-2008 08:07 PM
YJ bogs after 1min of driving. Tazjig YJ Wrangler Technical Forum 29 02-22-2007 08:40 AM
bogs down myheapofjeep YJ Wrangler Technical Forum 3 06-04-2003 10:47 PM
Engine Bogs Down. Need Help! Fatboy YJ Wrangler Technical Forum 1 09-09-2001 05:06 PM
